我们还在设计一个夹层PCB,有一个带状连接器,可以从一组1.27mm连接器桥接到另一组。
还推荐使用具有良好垂直轮廓的高密度连接器,用于板对板连接。 理想的是压合而不是焊接。 以上来自于谷歌翻译 以下为原文 We are still designing a mezzanine PCB, is there a ribbon cable like connector which can bridge from one set of 1.27mm connectors to the other set. Also recommended high density connectors with decent vertical profile for board to board connection. Ideally press-fit rather than soldered. |
4个回答
这是右下角显示的2x6连接器吗?
也许去看看SAM8780-ND 以上来自于谷歌翻译 以下为原文 Is this a 2x6 connector shown in the lower right corner? Maybe take a look at SAM8780-ND |
非常感谢能够适应威廉希尔官方网站
板的母头到板连接器的建议我计划使用这个通孔版本:FTS-106-01-F-D
digikey有相同的库存吗? 以上来自于谷歌翻译 以下为原文 Thanks a lot for the suggestion to adapt to the female part of the board to board connector I am planning to use this through hole version: FTS-106-01-F-D Does digikey have an equivalent in stock ? |
应用程序中的等效搜索功能非常棒。
以上来自于谷歌翻译 以下为原文 The equivalent search feature in the app is awesome. |
你好,
以下是我们提供的一些可能适合您的类似选项的链接。 https://www.digikey.com/short/jn7894查看它们,看看它们是否可以使它们适用于您的应用程序。 谢谢,鲍比 以上来自于谷歌翻译 以下为原文 Hello, Here is a link to some similar options that we carry that may work for you. https://www.digikey.com/short/jn7894 Take a look through them and see if you can make them work for your application. Thanks, Bobby |
3492 浏览 3 评论
539浏览 1评论
GMT+8, 2025-1-10 14:46 , Processed in 0.823774 second(s), Total 83, Slave 67 queries .
