你好,我想问社区成员,如果他们有任何经验,使用CYC68013A EZ-USB FX2LP USB微控制器来编程PSoC5?我正在查看PSoC5开发工具包的原理图,他们用这个设备连接到一个迷你USB连接器,然后你可以编程PSoC5。我想知道这是否是一个直接编程PSOC5的方法,如果使用这个USB微控制器有什么问题?
请分享您的意见。
谢谢,
乔
以上来自于百度翻译
以下为原文
Hello, I wanted to ask the community members if they had any experience using the CYC68013A EZ-USB FX2LP USB Microcontroller to program the PSoc5? I was looking over the schema
tics for the PSoc5 Development kit and they use this device to connect to a mini-USB connector which you can then program the PSoc5. I want to know if this is a straight forward approach to program the PSoc5 and if there were any problems using this USB microcontroller?
Please share any comments you may have.
Thanks,
Joe
