您好,对于一个项目,我必须通过TCP接收IP包,并在串行线路上传输信息。对于这个,我认为8位PIC是足够的。所以我已经开始用MCC和TCP/IP Lite堆栈进行测试。它很好,但是我有一个插座问题。当我在同一个端口上放置两个更多的插座时,只有一个(最后一个添加)工作。正常吗?限制?这是我最新的版本。我想知道是否有可能使用WiFi和这个堆栈。它将在局域网电缆不可用的地方进行交互。尼古拉斯
以上来自于百度翻译
以下为原文
Hello,
For a project, I have to receive IP packet over TCP and transmit informa
tions on a serial line.
For this, I think that a 8bits PIC is adequate. So I have started tests with MCC and the TCP/IP lite stack.
It works fine but I have a problem with sockets.
When I Put two ore more socket at the same PORT, only one (the last added) are working. Is it normal ? A limitation ?
I work this the lastest version of all.
Also, I would like know if there are a possibility to use WIFI with this stack. It will be interressing for locations where LAN cable are not available.
Nicolas
