我正在使用示波器“AGILENT TECHNOLOGIES,DSO-X 2002A,MY53280682,02.35.2013061800”。然后我将示波器连接到我的电脑和u***,我必须提到我正在使用VISA驱动程序进行连接,我从你那里得到了
然后我尝试用matlab(2013)中的仪器控制工具箱从示波器中捕获数据。所有的初步步骤都很好执行。但是当我尝试执行读取波形功能时,出现了一条错误信息: - ' 执行函数时发生错误。下标索引必须是正整数或逻辑。'我尝试了很多次,但问题没有得到解决。请问您能否给我一些解决问题的建议或请示范公司 为此提供解决方案?感谢你。急切等待你的答案,1.jpg275.5 KB 以上来自于谷歌翻译 以下为原文 I am using an oscilloscope "AGILENT TECHNOLOGIES,DSO-X 2002A,MY53280682,02.35.2013061800'.Then I connected the oscilloscope with my pc with u*** and I must mention that I'm using VISA driver for connection purpose that I got from your company's network.Then I have tried to capture data from the oscilloscope with instrument control toolbox in matlab(2013).All the preliminary steps were well executed.But when I attempted to execute the read waveform function,there an error message came:- 'An error occurred while executing the function. Subscript indices must either be real positive integers or logicals. ' I tried many times,but the problem is not resolved.please can you give me some suggestion regarding to solve that problem or ask the oscilloscope company to give a solution for this? Thanking you.Eagerly waiting for your answers, 附件 |
6个回答
拜托,有人建议解决这个问题..
以上来自于谷歌翻译 以下为原文 please,someone suggest some solution of this problem.. |
您收到错误的原因是您不能在TMTOOL中传递所需的参数。 READWAVEFORM接受多个输入参数,即Channel,WaveformSize,MaxTimeMilliseconds,WaveformArray。 你只传入'channel1'。 如果在输入字段中传入'channel1',1024,10,零(1,1024),则应该看到输出。 我建议您将输出用作ActualPoints,InitialX,XIncrement,这样您就不会丢失信息。 以上来自于谷歌翻译 以下为原文 The reason you are getting an error is you are nto passing in the required parameters in TMTOOL. READWAVEFORM takes in multiple input arguments namely Channel, WaveformSize, MaxTimeMilliseconds, WaveformArray. You have only passed in 'channel1'. If you pass in 'channel1', 1024, 10, zeros(1,1024) in the input field, you should see the output. I'd recommend that you use the output as ActualPoints, InitialX, XIncrement so you don't lose the information. |
删除重复的回复。 以上来自于谷歌翻译 以下为原文 Removing duplicate reply. |
1342 浏览 0 评论
2401 浏览 1 评论
2232 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1294浏览 1评论
792浏览 0评论
1084浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-28 06:30 , Processed in 1.865894 second(s), Total 85, Slave 69 queries .
