有人测试了CYW92606WCDEVALL的校准测试集,如安立MT852B吗?我的评估板在低和高频率下EDR灵敏度和BER地板测试失败。我认为它可能是从与RF信号内联路由的滤波器的滚降,但是在零欧姆电阻的离散中切换没有更好的效果。我还注意到,与离散的阻抗匹配是可怕的,而它是合理的过滤器。
以上来自于百度翻译
以下为原文
Has anyone tested the CYW92706WCDEVAL with a calibrated test set such as the Anritsu MT8852B? My evalua
tion board is failing the EDR Sensitivity and BER Floor tests at the low and high frequencies. I thought it might be rolloff from the filter that is routed inline with the RF signal, but switching in the discretes with the zero ohm resistors had no better effect. I also noticed that the impedance match with the discretes is awful, whereas it is decent with the filter.
