我最近买了一台NUC7PJYH,意图用它来运行PLEX。
我安装了16GB的G.Skill内存并安装了我正在使用的Intel LH6i SSD。 我已经安装了Linux Mint 19,一切都运行良好。 唯一安装的软件是Mint,PlexMediaServer,一些远程访问软件(VNC和NoMachine)。 一切都运行良好,并访问存储在某些NAS设备上的内容。 当我需要登录盒子时,我基本上让NUC坐在架子上并且一直在使用NoMachine和VNC(测试两者)。 我决定买一个小的HDMI LCD显示器,我可以在需要时连接。 我有一台Loncevon 10.1英寸高清TFT液晶显示器(价格相当便宜)。 显示器可以很好地连接到所有设备(其他笔记本电脑,DVD播放器,FireTV)但不能连接到NUC,但是NUC可以很好地连接到我家里的HDMI电视。 无论我尝试什么,Loncevon都不会显示任何信号,我尝试使用多条HDMI线缆。 我即将放弃尝试使用显示器,有点想我会问周围希望找到解决方案。 如果有人有任何建议,我愿意接受。 谢谢。 还有一点我尚未追求:我可以找到关于Loncevon显示器的一些信息。 我想我不应该期望在中国生产并在亚马逊上销售的70美元以下的产品得到很多支持。 但是,我确实注意到显然成功的设备上的HDMI规格是HDMI 1.2,我注意到NUC是HDMI 2.0。 我对这些标准一无所知,并认为这是研究的内容。 以上来自于谷歌翻译 以下为原文 I recently bought a NUC7PJYH with the intent of using it to run PLEX. I installed 16GB of G.Skill memory and had an Intel LH6i SSD laying around that I am using. I have installed Linux Mint 19 and everything is working great. The only software installed is Mint, PlexMediaServer, some remote access software (VNC and NoMachine). Everything is working well and accessing content stored on some NAS appliances. I essentially have the NUC sitting on a shelf running and have been using NoMachine and VNC (testing both) when I need to log into the box. I decided to get a small HDMI LCD display that I can hook up when needed. I got a Loncevon 10.1 inch HD TFT LCD color monitor (pretty cheap price). The monitor works fine connected to everything (other laptops, DVD player, FireTV) but not to the NUC, yet the NUC works fine connected to HDMI TVs that I have at the house. The Loncevon keeps displaying no signal no matter what I tried and I have tried using multiple HDMI cables. I am about to give up trying to use the display, bit thought that I would ask around hoping to find a solution. I am open to any suggestions if anyone have any. Thanks. An additional note that I have not yet pursued: I can find little information regarding the Loncevon display. I suppose that I should not expect much support for a sub $70 product that is made in China and sold on Amazon. However, I did note that the HDMI specs on the devices that are successful apparently are HDMI 1.2 and I noticed that the NUC is HDMI 2.0. I am pretty ignorant of these standards and guess it is something to research. |
输出到仅符合HDMI 1.2规范的显示器应该不是问题。
也就是说,我不明白这种情况会出现什么问题; 从理论上讲,它应该起作用。 您是否尝试将其作为第二个显示器挂钩? 将电视/显示器连接到HDMI连接器,并将此便携式显示器连接到USB-C连接器(为此需要USB-C到HDMI适配器)。 内容S 以上来自于谷歌翻译 以下为原文 Outputting to a display that is only compliant to the HDMI 1.2 specification should not be an issue. That said, I don't understand what is going wrong in this scenario; it should, in theory, work. Have you tried hooking it up as a second display? Connect a TV/monitor to the HDMI connector and connect this portable monitor to the USB-C connector (you would need a USB-C-to-HDMI adapter for this). ...S |
538浏览 0评论
GMT+8, 2025-1-14 01:54 , Processed in 0.638267 second(s), Total 74, Slave 59 queries .
