编程头具有PSoC 5部分号CY8C5868 LTI-LP039 QFN68。你可以用它作为PSoC 5并像目标板一样编程。注意一些线路上的通行证。由于这个特性,您有能力将您自己的PSoC 5LP代码引导到设备中。通过这样做,您可以覆盖自定义项目的现有PSoC 5LP功能。不要担心重写PSoC 5LP代码,您可以轻松地将PSoC 5LP还原为其工厂设置,作为程序员和调试器。此引导加载程序允许您尝试PSoC 5LP设备,并使您的先锋工具包成为双臂开发平台。看到它的PSoC 4板,但它是相同的为您的董事会www. com /Cultuth/Trabe/25084/L/PSOC-4先锋- KIT-Cultudio项目036WAT-I CAN-USE-PSOC-5LP-太
以上来自于百度翻译
以下为原文
The programming header has a PSOC 5 part number CY8C5868LTI-LP039 QFN68. You can use this as a PSOC 5 and program it just like the target board. Watch out for By-pass caps on some of the lines.
. Due to this feature you have the ability to bootload your own custom PSoC 5LP code into the device. By doing this you overwrite the existing PSoC 5LP functionality for your custom project. Don’t worry about overwriting the PSoC 5LP code, you can easily restore the PSoC 5LP to its factory setting as a programmer and debugger. This bootloader allows you the opportunity to try out the PSoC 5LP device and enable your Pioneer kit as a dual ARM development platform. See this its for the PSOC 4 board but it's the same for your board www.element14.com/community/thread/25084/l/psoc-4-pioneer-kit-community-project036-what-i-can-use-the-psoc-5lp-too
以上来自于百度翻译
以下为原文
