Cypress技术william hill官网
杜元晓
7年用户 214经验值
带CY8CKIT-024调谐器的CY8CKIT-042套件不起作用
大家好,
在我第一次体验CY8CKIT-042先锋套件时,我使用了像线性滑块那样的示例项目。
我也尝试了一些变化,只使用一个滑块元素作为一个按钮。
启动调谐器总是工作得很好。
但现在我开始使用CY8CKIT-024 CAPSENSE接近盾。我使用以下CyPress产品页面的示例项目:
HTTP://www. CyPress .COM/DICONtiON/APPLION-NOTES/AN92249近距离感测
不管我尝试什么样的项目(我只使用那些用0042命名的项目),没有一个让我用调谐器工作。调谐器总是抛出:
“读取操作失败!CKII2C连接“。
EZI2C SCB块的所有设置与文档AN92249完全匹配,这也是我在前面提到的链接中找到的。
更新组件,建立和闪烁工作良好(我使用PSoC创建者4.1)。
有什么我可以忘记的设定吗?
谢谢!
以上来自于百度翻译
     以下为原文
  Hello together,
during my first experiences with the CY8CKIT-042 Pioneer Kit i worked with example projects like the one with the linear slider.
I also tried some variations by using only one of the slider elements as a button.
Starting the Tuner always worked well.
But now i started to work with the CY8CKIT-024 CAPSENSE PROXIMITY SHIELD in addition. I use the example projects from the following Cypress product page:
http://www.cypress.com/documentation/application-notes/an92239-proximity-sensing-capsense
Doesn't matter which example project i try (i only use the ones that are named with 0042), none of them lets me work with the Tuner. The tuner always throws:
"Read operation failed! Ceck I2C connection".
All my settings of the EzI2C SCB block exactly match the document AN92239, which is also to be found on the link i mentioned before.
Updating components, Building and Flashing were working well ( I'm using PSoC creator 4.1).
Is there any setting that i may could have forget?
Thanks a lot!
回帖(2)
罗红
2018-11-16 15:13:37
您需要将宏“调谐器启用”设置为1,以使用调谐器。
当调谐器被启用时,LED控制不起作用,因为我们进入不定环:
以上来自于百度翻译
     以下为原文
  You need to set the macro "Tuner Enable" to 1, to use the tuner.
When tuner is enabled, the LED control does not work because we enter a indefinite loop:
杜元晓
2018-11-16 15:20:31
哇,谢谢,伙计!
以上来自于百度翻译
     以下为原文
  Wow thanks a lot man!
