你好,MrNeato。
非常感谢您与英特尔社区团队分享您的问题。
我将非常乐意为您提供帮助。英特尔®驱动程序&
支持助手它实际上为您的NUC提供最新的驱动程序。
在这种情况下发生的是,您目前已经为您的控制器安装了最新的图形和读卡器驱动程序,这些驱动程序是比英特尔®NUC可用的版本更新的版本。这是因为您的NUC的驱动程序已经过测试,
另一方面,专门为此设备修改,控制器的驱动程序是通用驱动程序,通过安装它们,结果可能会有所不同。我希望这可以回答你的问题.Antony S.
以上来自于谷歌翻译
以下为原文
Hello,
MrNeato. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
The Intel® Driver & Support Assistant it is actually providing the latest drivers for your NUC. What is happening in this case, is that you currently have installed the latest Graphics and Card Reader drivers for your controllers, which are newer versions than the ones available for the Intel® NUC.
This happens because the drivers for your NUC have been tested and modified specially for this device, on the other hand, the drivers for the controller are generic drivers and, by installing them, the results may vary.
I hope this answers your question.
Antony S.
你好,MrNeato。
以上来自于谷歌翻译
以下为原文
Hello,
Antony S.
