听起来您的设备正处于该范围的功能边缘。
如果您的设备降低系统功率,那么我可以看到它导致重启的位置。
我还可以看到问题只会在您尝试保存数据时浮出水面。
我怀疑当磁盘驱动器中的电机试图旋转磁盘时,它会消耗最多的电量。
验证发生了什么的唯一方法是构建一个可以让您查看USB总线上的电压和电流的夹具。
我只想到了一个潜在的解决方案......我看过'Y'电缆允许2个USB端口驱动一个设备,事实上我有一些USB硬盘驱动器。
如果您使用其中一个连接到外部电源,您可能可以避免此问题。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦william hill官网
在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
Sounds like your device is sitting right at the edge of the power capabilities of that scope.
If your device draws down system power, then I can see where it cause a reboot.
I can also see that the problem would only surface when you try to save data. I suspect that's when the motor in the disk drive is trying to spin up the disk, and it draws the most power.
The only way to verify what's happening would be to build a fixture that would allow you to look at the voltage and current on the USB bus.
I just thought of a potential solution... I have seen 'Y' cables that allow 2 USB ports to drive one device, in fact I have a few on USB hard drives. If you use one of those, connected to an external supply, you might be able to avoid this problem.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
听起来您的设备正处于该范围的功能边缘。
安捷伦william hill官网
以上来自于谷歌翻译
以下为原文
Al
