嗨,
我想将英特尔实感D435用于Qt 5.10.1的新项目。 我试图运行示例“rs-capture.cpp”(librealsense / rs-capture.cpp在master·IntelRealSense / librealsense·GitHub)。 构建成功,但每当我执行它时,它都会崩溃。 崩溃发生在pipe.start()(第23行),错误:0x7ffa7dd5643a异常,代码:0xc0000005:读取访问冲突:0xffffffffffffffff,flags = 0x0(第一次机会)。 任何人都可以告诉我这是硬件,库等问题吗? 我检查了任何遗漏的依赖项,但它们都很好。 我的设置: Windows 10专业版1703 API版本2.15.0 固件版本5.10.3 非常感谢你! 以上来自于谷歌翻译 以下为原文 Hi, I want to use the Intel RealSense D435 for a new project with Qt 5.10.1. I tried to run the example "rs-capture.cpp" (librealsense/rs-capture.cpp at master · IntelRealSense/librealsense · GitHub). The build succeeds, but whenever I execute it, it crashes. The crash occurs at pipe.start() (line 23) with the error: Exception at 0x7ffa7dd5643a, code: 0xc0000005: read access violation at: 0xffffffffffffffff, flags=0x0 (first chance). Can anybody please tell me if this is a problem with the hardware, the library etc.? I checked for any missing depencies, but they were all fine. My setup: Windows 10 Pro Version 1703 API version 2.15.0 Firmware version 5.10.3 Thank you very much! |
3个回答
这种Windows访问冲突(它不是源自RealSense)显然有很多原因,因此难以诊断。
内存问题,病毒或糟糕的Windows注册表是最常见的原因。 它也可能是由于无法找到文件引起的。 windows - 访问冲突的范围究竟是什么'0xc0000005'? - 堆栈溢出 以上来自于谷歌翻译 以下为原文 This Windows access violation (it does not originate with RealSense) apparently has numerous causes, making it hard to diagnose. Memory issues, viruses or a bad Windows registry are among the most common causes. It may also be caused by being unable to locate a file. windows - What exactly is the scope of Access Violation '0xc0000005'? - Stack Overflow |
谢谢您的回答。
一段时间后我解决了这个问题,它根本与RealSense SDK无关。 以上来自于谷歌翻译 以下为原文 Thank you for your answer. After some time I solved the problem, it had nothing to do with the RealSense SDK at all. |
真棒新闻,感谢您告诉我们。 祝你有美好的一天! 以上来自于谷歌翻译 以下为原文 Awesome news, thanks for letting us know. Have a great day! |
GMT+8, 2025-3-30 01:08 , Processed in 0.605194 second(s), Total 80, Slave 62 queries .
