赛灵思
王玉英
7年用户 286经验值
ISE Design suite 10.1安装问题
嗨,
我在计算机上安装ISE Design Suite 10.1后遇到了一些麻烦。
ISE Design suite 10.1已成功安装(也更新到sp3)。
但是,当我打开XPS工具时,我只能在右侧看到窗口的一小块区域(以下照片是屏幕快照)。
我必须单击鼠标右键并选择“浮动”选项,然后我才能看到整个屏幕。
我尝试再次安装软件,但情况是一样的。
这对我来说非常不方便,因为我每次都必须对每个窗口执行相同的操作。
有谁知道问题是什么?
我很感激一些帮助。
非常感谢。
以上来自于谷歌翻译
以下为原文
Hi,
I suffered some troubles after I installed ISE Design suite 10.1 on my computer.
The ISE Design suite 10.1 is installed successfully (also update to sp3). However, When I open the XPS tool, I can only see a small area of the window on the right side (the following photographs are the screen snapshot).
I have to click the right button of mouse and choose the "float" option then I would be able to see the whole screen.
I try to install the software again but the situation is the same. This is very inconvenient for me because I have to do the same action for each window each time.
Does anyone know what the problem is?
I'd appreciate some help. Thanks a lot.
回帖(3)
曾玲娟
2018-11-26 14:54:58
其他人报告了某些Windows主题的类似问题:
http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270(无法正确查看窗口)
BT
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Others have reported similar problems with certain Windows themes:
http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270 (can't see windows correctly)
bt
View solution in original post
曾玲娟
2018-11-26 15:02:49
BT
以上来自于谷歌翻译
以下为原文
bt
王丽娟
2018-11-26 15:10:59
解决方案非常有用,而且很有效。
非常感谢。
以上来自于谷歌翻译
以下为原文
The solution is very helpful and it works.
Thank you so much.
