我使用控制台项目来测试两个CYW43907 EVKS中的WiFi性能。一个是AP,另一个是STA。
如果我想在AP和STA之间进行5G的测试,我应该设置命令吗?
我猜想,在StaseTap AP命令中,如果信道号是153,那么AP是否工作在5G?哪个频道号码是5G?
以上来自于百度翻译
以下为原文
I use the console project to test wifi performance in two CYW43907 EVKs. One is AP, antother is STA.
If I want to have a test in 5G between AP and STA, should I set up the command?
I guess that, In the start_ap command, if the channel number is 153, dose the AP work in 5G? Which channel number is for 5G?
