您好,我下载了最新版本的st-motor-control。当我打开一个例子时,该软件告诉我我正在使用更新的版本,并且必须从4.3迁移到5.0.2。我接受。
现在,
我可以打开监视器窗口,我可以控制引擎。如果我想修改配置并生成它,软件会告诉我我不能这样做,因为“FW for SDK 5.0不支持F1 mcus”
当我加载示例时,我有以下信息:
App:STMCWB
时间:05/30/2018 08:38:42
项目:Noname
文件名:F: MHK
STM32 STEVAL3201 Noname.logType时间电机ID消息
UNK 08:06:41 SDK5.0的FW不支持'无传感器(HFI +观察者)'。所有参数都将被禁用。
UNK 08:06:41 SDK5.0的FW不支持'PFC'。所有参数都将被禁用。
UNK 08:06:41 F5 for SDK5.0不支持'LCD'。所有参数都将被禁用。
UNK 08:06:41 F5 for SDK5.0不支持F1 mcus
UNK 08:06:41 F5 for SDK5.0不支持F2 mcus
UNK 08:06:41 SDK5.0的FW不支持STSPIN mcu我在哪里可以找到sDK vesion 4.3?
谢谢。
基督教
以上来自于谷歌翻译
以下为原文
Hello, I downloaded the latest version of st-motor-control. When I open an example, the software informs me that I am using a newer version and must migrate from 4.3 to 5.0.2. I accept.
Now,
I can open the monitor window and I can control the engine. If I want to modify the configura
tion and generate it, the software informs me that I can not do it because 'F1 mcus not supported in FW for SDK 5.0'
When I load the example, I have the following information:
App: STMCWB
Time: 05/30/2018 08:38:42
Project: Noname
Filename: F:MHKSTM32STEVAL3201Noname.logType Time Motor Id Message
UNK 08:06:41 The 'Sensor-less (HFI+Observer)' is not supported in the FW for SDK5.0. All parameters will be disabled.
UNK 08:06:41 The 'PFC' is not supported in the FW for SDK5.0. All parameters will be disabled.
UNK 08:06:41 The 'LCD' is not supported in the FW for SDK5.0. All parameters will be disabled.
UNK 08:06:41 F1 mcus are not supported in the FW for SDK5.0
UNK 08:06:41 F2 mcus are not supported in the FW for SDK5.0
UNK 08:06:41 STSPIN mcu is not supported in the FW for SDK5.0Where can I find an sDK vesion 4.3 ?
Thank.
Christian
