嗨,
从以下链接下载ISE 10.1:http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v10_1.html
单击旁边的“获取v10.1注册ID”以获取注册ID。
谢谢。
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
Download ISE 10.1 from the link: http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v10_1.html
Click on "Obtain a v10.1 Registration ID" beside it to get a reg ID.
Thanks.
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post
嗨,
谢谢。
如果没有,你应该在发布之前。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
Thanks.
