好吧,如果它是Webpack,您可能会遇到任何64位操作系统,Windows或其他问题。
除了安装32位版本之外,我不知道Windows上是否有任何解决方案。
然而,Webpack在OpenSuse 11 64位下工作得很好,安装了32位兼容库。
您必须在setup.sh脚本中注释掉“exit”,它会检测到64位Linux并且想要放弃;
然后它会愉快地继续安装和工作。
(其他64位Linux发行版可能也可能不起作用,如果它们具有32位兼容库;我还没试过。)
以上来自于谷歌翻译
以下为原文
Well if it's Webpack, you may have problems with any 64-bit OS, Windows or otherwise.
I don't know if there is any resolution on Windows except to install a 32-bit version.
However Webpack works just fine under OpenSuse 11 64-bit, with the 32-bit compatibility libraries installed.
You have to comment out the "exit" in the setup.sh script where it detects a 64-bit Linux and wants to give up;
it will then happily go on to install, and work.
(Other 64-bit Linux distros may or may not work too, if they have the 32-bit compatibility libraries; I haven't tried.)
然后它会愉快地继续安装和工作。
以上来自于谷歌翻译
以下为原文
