您好!
对于AD8343 S参数的使用产品线工程师解释如下,供您参考。
Is there any reason you chose AD8343 over its next generations: AD8342 and ADL5801? Both AD8342 and ADL5801are higher performance active mixers, and much easier to use because of their boardband characteristics.
AD8343 s-parameters are provided for purposes of input/output matching, but not freqeuncy conversion simulation. If you look into the s2p file, you will see all 4 parameters were measured under the same corresponding freqeuncy. This means no freqeuncy translation was involved, or LO was zero. In this case, s12 and s21(aka gain for its magnitude) are not useful data for any mixer simulation, but s11 and s22 have valuable service for impedance matching. Once you find the proper matching for the mixer at desired band, you would need to implement the matching on a prototype board rather than relying on any simulation.
Regarding the stability consideration, page 21 and 22 have the full discussion. I'm not sure if I can add anything else. Once you set up the mixer on board, you should be able to see if there is any oscillation to verify your stabilty.
您好!
