* @brief Writes data to the specified GPIO data port.
* @param GPIOx: where x can be (A or B) to select the GPIO peripheral.
* @param GPIO_PinSource: specifies the pin for the Alternate function.
* This parameter can be GPIO_PinSourcex where x can be (0..15).
* @param GPIO_AF: selects the pin to used as Alternate function.
* This parameter can be one of the following value:
* @arg GPIO_AF_0: WKUP, EVENTOUT, TIM15, SPI1, TIM17,MCO, SWDAT, SWCLK, TIM14,
* USART1, CEC, IR_OUT, SPI2
* @arg GPIO_AF_1: USART2, CEC, Tim3, USART1, IR_OUT,EVENTOUT, I2C1, I2C2, TIM15
* @arg GPIO_AF_2: TIM2, TIM1, EVENTOUT, TIM16, TIM17
* @arg GPIO_AF_3: TS, I2C1, TIM15, EVENTOUT
* @arg GPIO_AF_4: TIM14, I2C1 (only for STM32F0XX_LD and STM32F030X6 devices)
* @arg GPIO_AF_5: TIM16, TIM17
* @arg GPIO_AF_6: EVENTOUT
* @arg GPIO_AF_7: COMP1 OUT, COMP2 OUT
* @note The pin should already been configured in Alternate Function mode(AF)
* using GPIO_InitStruct->GPIO_Mode = GPIO_Mode_AF
* @note Refer to the Alternate function mapping table in the device datasheet
* for the detailed mapping of the system and peripherals'alternate
* function I/O pins.
* @retval None
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
uint32_t temp = 0x00;
uint32_t temp_2 = 0x00;
/* Check the parameters */
assert_param(IS_GPIO_LIST_PERIPH(GPIOx));
assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource));
assert_param(IS_GPIO_AF(GPIO_AF));
temp = ((uint32_t)(GPIO_AF) << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4));
GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4));
temp_2 = GPIOx->AFR[GPIO_PinSource >> 0x03] | temp;
GPIOx->AFR[GPIO_PinSource >> 0x03] = temp_2;
默认是 GPIO_AF_0,是swd,那做普通io呢?
* @retval None
