您好,当前:这里程序SC(从栈代码V5.11)是从处理器板PIC32 MX795F512L上运行的。PIC32 MX与CHIPLAN9252之间的通信工作正确,VIASPI。RT 0(I/OUT)闪存,LED运行,从端口1(OUT)的LED链路/动作是关闭的。配置:端口0和1连接到内部PHYS A和B。端口2连接到外部MII引脚。POT0(I/OUT)通过EtCCAT.PUT1(OUT)和POT2连接到嵌入式PC BEKKHOFF CX1100-004(用于LA)N9252-AddioBoad没有连接到EXTEN。文件在Twitter 2.0的结构窗口中列出:框1、BOX2和BOX3。BOX1和BOX2有错误的错误。框3在OP模式下正确工作。看到下面的一些图片。我不明白为什么在Twitter 2的结构窗口中存在框1和框2。我找不到这个错误。我怎样才能从结构窗口中移出框1和框2?我希望失去这个问题。端口0和1连接到内部PHS A和B。端口2连接到外部MII PIN。最好涉及GEWWB70。
以上来自于百度翻译
以下为原文
Hello,
current: here the program SSC (slave stack code v5.11) is running on the processor PIC32MX795F512L from the demoboard. The communication between the PIC32MX and the chip LAN9252 works correctly via SPI.
After the EEPROM-programming and device-sanning with Twincat2.0 was sucessfully.
LED LINK/ACT from PORT 0(IN/OUT) flashs, the LED RUN is ON, and LED LINK/ACT from PORT 1(OUT) is OFF.
Configation: Ports 0 and 1 are connected to internal PHYs A and B. Port 2 is connected to the external MII pins.
PORT0(IN/OUT) is connected to the embedded PC BECKHOFF CX1100-0004 via ethercat.
PORT1(OUT) and PORT2 (for LAN9252-ADD-ON board) are not connected to extern.
The files was listed in the structur window from Twincat2.0: Box 1, Box2 and Box3. Box 1 and Box 2 have error INIT INIT_ERR. Box 3 works correctly in OP mode. See some pictures below.
I don't understand why do exist Box 1 and box 2 in the structur window from twincat 2.0? I can not find this mistake.
How can I remove Box 1 and Box 2 from the strucktur window?
I hope to lose this problem.
best regards
GeWoBl70
Attached Image(s)
以上来自于百度翻译
以下为原文
Hello,
best regards
GeWoBl70
Attached Image(s)
