是德科技
董超
7年用户 266经验值
E4438C网络不起作用
我正在尝试将arb文件加载到设备上。
唯一可行的配置是直接连接到设备的Windows XP笔记本电脑。
每个地址都设置为同一C类网络范围内的唯一地址。
以相同方式配置的Windows 7笔记本电脑不起作用。
Linux工作站也不起作用。
该设备上的固件已升级到最新版本(奇怪的是,在Linux笔记本电脑上使用Windows 7 VM成功完成)有关如何让该设备在普通网络上运行的任何建议吗?
以上来自于谷歌翻译
     以下为原文
  I am trying to load arb files onto the unit.  The only configuration that seems to work is a Windows XP laptop directly connected to the unit.  Each has its address set to a unique address in the same Class C network range.  A Windows 7 laptop configured the same way does not work.  A Linux workstation also do not work.  The firmware on the unit has been upgraded to the latest version (curiously enough successfully done with a Windows 7 VM on a Linux laptop)
Any suggestions on how to get this unit to work on a normal network?
回帖(1)
李欢
2018-11-29 11:23:55
嗨 - 如何从笔记本电脑中将arb文件加载到仪器中?
使用FTP,Intuilink和Toolkit可以使用一些方法进行传输。
对于Windows 7,将arb文件传输到仪器应该没有任何问题。
以下是Signal Generator产品的编程指南:http://cp.literature.agilent.com/litweb/pdf/E8251-90355.pdf,请参阅第5章 - 下载波形。
问候 -
以上来自于谷歌翻译
     以下为原文
  Hi -
How are the arb files loaded to the instrument from the laptop?
There are a few methods to transfer, using FTP, Intuilink, and Toolkit.
As for the Windows 7, there shouldn’t be any problem transferring arb files to the instrument.
Here is the programming guide for Signal Generator products: http://cp.literature.agilent.com/litweb/pdf/E8251-90355.pdf , please refer to Chapter 5 - downloading waveforms.
Regards -
