您没有说明如何生成QPSK信号,或者未生成QPSK信号时生成的信号。
范围不知道它是QPSK。
如果您可以在QPSK序列开始时改变电压的外部信号,或者您的信号在开始时从关闭变为开启,则可以设置触发。
除此之外,这是值得怀疑的。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦william hill官网
在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
You don't say how you are generating the QPSK signal, or what happens on the line when it's not being generated. The scope has no idea it's QPSK. If you can generate at an external signal that changes voltage at the beginning of a QPSK sequence, or your signal goes from off to on at the beginning, then it's possible to set up a trigger. Other than that, it's doubtful.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
范围不知道它是QPSK。
除此之外,这是值得怀疑的。
安捷伦william hill官网
以上来自于谷歌翻译
以下为原文
Al
