嗨,
我有一台3D系统的3D扫描仪,配有英特尔实感SR300摄像头。 我想知道是否有人知道扫描仪附带的软件中低到高几何分辨率的含义。 提前谢谢你花时间回答我的问题。 以上来自于谷歌翻译 以下为原文 Hi, I have a 3D scanner from 3D Systems that has the Intel RealSense SR300 camera. I would like to know if there is someone that know the meaning of low to high geometry resolution in the software that come with the scanner. Thank you in advance to take the time to answer my question. |
5个回答
您使用的是3D Systems的Sense 2扫描仪吗?
如果是这样,用户手册会说低分辨率到高分辨率选择“较高的值会消耗更多的处理能力和内存,并可能导致扫描过程延迟”。 在设备的前身手册中,第一个Sense,它表示“分辨率决定了采集的扫描数据的密度;更高的分辨率将产生更密集的扫描,但可以降低捕获速度”。 http://cubify.s3.amazonaws.com/Scanners/Sense/sense_2nd_gen_user_guide_win.pdf 以上来自于谷歌翻译 以下为原文 Are you using the Sense 2 scanner from 3D Systems, please? If so, the user manual says about low to high resolution selection that "higher values will consume more processing power and memory, and may cause delays in the scanning process". In the manual of the device's predecessor, the first Sense, it says "resolution determines the density of the scan data acquired; higher resolution will yield denser scans, but can slow down the capture speed". http://cubify.s3.amazonaws.com/Scanners/Sense/sense_2nd_gen_user_guide_win.pdf |
nywerwer 发表于 2018-11-30 16:36 是的,我正在使用3D Systems的Sense 2扫描仪。 我也发现了这些信息,但我正在寻找更多细节,例如分辨率数字或扫描仪软件中的低电平与英特尔实感SR300相机的关联。 换句话说,我找到了英特尔实感SR300相机的产品数据表,并想知道Sense 2软件中找到的4个级别的分辨率。 谢谢 以上来自于谷歌翻译 以下为原文 Yes, I'm using the Sense 2 scanner from 3D Systems. I found also that information, but I'm looking for more detail such as resolution numbers or the association of low in the scanner software to the Intel RealSense SR300 camera for example. In other words, I found the product datasheet of the Intel RealSense SR300 camera and would like to know to which resolution the 4 levels find in the Sense 2 software are associated to. Thanks |
WHR197 发表于 2018-11-30 16:46 有时,包含RealSense相机的产品不会作为RealSense相机进行分类,而是作为其他产品。 例如,英特尔项目合金VR耳机包含RealSense ZR300相机,但未升级为RealSense设备。 英特尔Euclid是一款糖果条大小的迷你计算设备,其中还装有ZR300但未作为相机销售。 Sense 2扫描仪属于相同的情况,包含SR300相机但未被提及为RealSense设备。 简而言之,Sense 2是那些难以分类的设备之一,它与RealSense相机的不同之处在于它们无法直接与英特尔销售的相机进行比较。 即使在3D Systems自己的设备文档和数据表中,所有关于其分辨率的知识都是它的最大深度分辨率为640x480,最大色彩分辨率为1920x1080。 没有提到低于这些设置的可选分辨率 - 只能通过滑块降低分辨率。 以上来自于谷歌翻译 以下为原文 Sometimes products that contain RealSense cameras are not cateorized as RealSense cameras, but as something else. For example, the Intel Project Alloy VR headset contained a RealSense ZR300 camera but was not promoted as a RealSense device. The Intel Euclid, a candy-bar sized mini computing device, also had a ZR300 in it but was not marketed as a camera. The Sense 2 scanner falls into the same situation, containing an SR300 camera but not being mentioned as a RealSense device. In short, Sense 2 is one of those hard to categorize devices where it is different enough from RealSense cameras that they cannot be directly compared to the cameras that Intel sell. All that seems to be known about its resolutions, even in 3D Systems' own documentation and data sheet for the device, is that it has a maximum depth resolution of 640x480 and a maximum color resolution of 1920x1080. There is no mention of selectable resolutions lower than those settings - only that resolution can be lowered with a slider. |
nywerwer 发表于 2018-11-30 16:58 非常感谢你的回答和你的时间我不知道这可能存在,但对于Sense 2扫描仪来说,这很好。 以上来自于谷歌翻译 以下为原文 Thank you so much for your answer and your time I didn't know this could exist, but it's good to know for the Sense 2 scanner. |
我同样发现了这些数据,但是我正在寻找更多的细节,例如Audacity,目标数字或者扫描仪编程与英特尔实感SR300相机的低关系。
就像这样的Origin,我找到了英特尔实感SR300相机的项目数据表,可能想知道Sense 2编程中4个级别找到的Find My iPhone目标与哪个相关。 以上来自于谷歌翻译 以下为原文 I found likewise that data, however I'm searching for more detail, for example , goals numbers or the relationship of low in the scanner programming to the Intel RealSense SR300 camera for instance. As such , I found the item datasheet of the Intel RealSense SR300 camera and might want to know to which Find My iPhone goals the 4 levels find in the Sense 2 programming are related to.
527浏览 0评论
GMT+8, 2025-1-1 23:04 , Processed in 0.737433 second(s), Total 86, Slave 70 queries .
