赛灵思
朱志兴
7年用户 298经验值
Windows 7 64位上的14.7安装问题
我正在运行Windows 7 Professional 64位SP1。
我安装了14.7,安装似乎没问题。
但是当我在ISE中创建一个项目并尝试合成时,我收到一条错误消息:
INTERNAL_ERROR:可移植性:basutencodeimp.c:229:1.24  - 查看的字节数与请求的字节数不匹配。
文件损坏了吗?
错误:分析程序 -  SSLex0102e:无效的文件长度或读取错误,C:/Xilinx/14.7/ISE_DS/ISE/data/Pr_Logical.dfa,2ERROR:分析程序:10  - 创建解析引擎时出错。
请检查数据目录以查看是否已正确安装.dfa和.llr文件,以及是否正确设置了路径和权限以访问这些文件.ERROR:分析程序 -  SSLex0102e:文件长度无效或读取错误,C:/ Xilinx
/14.7/ISE_DS/ISE/data/Pr_Logical.dfa,0ERROR:Parsers:10  - 创建Parse引擎时出错。
/14.7/ISE_DS/ISE/data/Pr_Logical.dfa,2ERROR:Parsers:10  - 创建Parse引擎时出错。
请检查数据目录以查看是否已正确安装.dfa和.llr文件,以及是否正确设置了路径和权限以访问这些文件。阅读设计:fir_test.prj
我从PlanAhead 14.7得到了类似的错误。
我一直在我的系统上运行14.5没有问题。
我尝试卸载并重新安装14.7并观察所有警告,但没有任何迹象表明安装问题。
14.7与我们的许可证服务器连接。
14.7适用于我们办公室中使用相同的存档14.7下载文件和相同许可证服务器的其他计算机。
建议?
Al Zachary
以上来自于谷歌翻译
以下为原文
I am running Windows 7 Professional 64 bit SP1.  I installed 14.7 and the installation appeared to go OK.  But when I create a project in ISE and try to synthesize i get an error message:
INTERNAL_ERROR:Portability:basutencodeimp.c:229:1.24 - Number of bytes peeked does not match number of bytes requested.  Corrupted file?
ERROR:Parsers - SSLex0102e: Invalid file length or read error, C:/Xilinx/14.7/ISE_DS/ISE/data/Pr_Logical.dfa, 2
ERROR:Parsers:10 - Error occurred while creating Parse engine.  Please check the data directory to see that the .dfa and .llr files have been properly installed and that the paths and permissions are properly set to access these files.
ERROR:Parsers - SSLex0102e: Invalid file length or read error, C:/Xilinx/14.7/ISE_DS/ISE/data/Pr_Logical.dfa, 0
Reading design: fir_test.prj
I get a similar error from PlanAhead 14.7.
I have been running 14.5 on my system without problems.  I have tried uninstalling and re-installing 14.7 and observing all warnings, but nothing indicates an installation problem.
14.7 is connecting with our license server.  And 14.7 works on other computers in our office that use the same archived 14.7 download file and the same license server.
Suggestions?
Al Zachary
回帖(5)
陈衡毅
2018-12-4 11:18:39
您好,您可以尝试以下检查安装状态。要检查文件是否正确下载,下载文件的MD5校验和值应与下载文件的MD5总和值匹配(Xilinx网站 - >支持 - >下载
).MD5sum可以从http://www.fastsum.com/下载。在将.tar文件提供给FastSum工具后,它将显示文件的Checksum  state值。将校验和 state列值与下载时提供的值进行比较
Xilinx上的页面。
如果不匹配,则表示下载的文件未完成或已损坏。您必须再次从Xilinx网站下载Vivado。
http://www.xilinx.com/support/download/index.htm如果MD5校验和值与下载的文件匹配,则使用7zip软件解压缩,因为7-zip用于压缩软件。可以从http://下载
www.7-zip.org/(解压缩时请保持层次结构完整)建议在解压缩或解压缩下载文件时关闭防病毒软件。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
You may try the following to check the installation status.
To check if the file was downloaded correctly, MD5 checksum value of downloaded file should match with MD5 sum value from where file was downloaded (Xilinx website-->support-->download).
MD5sum can be downloaded from http://www.fastsum.com/
After feeding your .tar file to FastSum tool, it will display Checksumstate value of file.
Compare the checksumstate column value with the value provided at download page on Xilinx.
If there is mismatch, it means that the downloaded files are not complete or corrupted.
You must again download Vivado from Xilinx website. http://www.xilinx.com/support/download/index.htm
If MD5 checksum value matches with downloaded file then Use 7zip software to unzip since 7-zip was used for zipping the software.
It can be downloaded from http://www.7-zip.org/ (Please keep the hierarchy intact when unzipping)
It is recommended to turn off anti-virus when unzipping or extracting downloaded file.
Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.View solution in original post
陈衡毅
2018-12-4 11:29:56
Xilinx上的页面。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,Vijay
陈衡毅
2018-12-4 11:37:16
嗨,你的问题解决了吗?
如果是,请通过标记为解决方案来关闭线程。
以上来自于谷歌翻译
以下为原文
Hi,
Is your issue solved? If yes please close the thread by marking as solution.Thanks,Vijay
向可嘉
2018-12-4 11:46:27
我不能说azachary但我有相同的错误信息,你提供的步骤帮助我解决了问题。
14.7现在的工作就像一个魅力。
带来新鲜感
以上来自于谷歌翻译
以下为原文
I can't speak for azachary but I was having the same error message and the steps you provided helped me fix the issue. 14.7 is  now working like a charm.
bring the fresh
