感谢你的帮助。
我正在尝试从1天开始将“部分”生成的许可证从我的VM移动到我正在运行VIVADO的工作站。
我按照说明将许可证返还给xilinx,以便为另一台机器获取新的许可证。
问题是,许可证似乎被锁定到我的VM,但是当我运行程序(命令行)来释放许可证时,该工具告诉我安全spce中没有内容 - 我想这是因为它没有'
工作正常。
看看Xilinx lincese管理网站,我看到为VM激活了2个许可证,但我无法访问webbrowser中的“修改许可证”按钮 - 它显示为灰色。
我可以再次询问您的帮助,或任何描述类似行为的文件/网站吗?
以上来自于谷歌翻译
以下为原文
Thanks for all your help.
I'm trying since 1 day to move the "partially" generated license from my VM to the workstation on which I'm running VIVADO.
I've followed the instructions to return a license to xilinx in order to get a new one for the other machine. The problem is, the license seems to be locked to my VM, but when I run the procedure (command line) to release the license, the tool is telling me there is no content in the secure spce - I guess thats because it didn't work properly.
Looking at the Xilinx lincese management web site, I see 2 licenses activated for the VM, but I can't access the "modify license" button in the webbrowser - it's greyed out.
May I ask once more for your assistance, or any document / site that describes a similar behaviour?
感谢你的帮助。
工作正常。
以上来自于谷歌翻译
以下为原文
