赛灵思
陈福蓓
7年用户 160经验值
Vivado的PR许可证是否与ISE不同?
你好
假设用于ISE的许可证也可用于Vivado?
以上来自于谷歌翻译
以下为原文
Hi
Does PR licence for vivado is different than ISE ??
suppose licence that is used for ISE can also be used for Vivado?
回帖(1)
姚庭芳
2018-12-11 11:38:22
对于ISE和Vivado,HelloPR许可证是相同的。如果您有版本限制,那么您可以使用与Vivado.Thanks,Vinay相同的PR许可证。
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hello
PR license is same for ISE and Vivado.
If you have version limit, then you can use the same PR license with Vivado.
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
