我有一个4端口N5241A(固件更新到最新的产品版本),我用它来测试双工变频器。
我的分析仪设置为使用端口3和4测量SMC +相位,IMDx和NFX(每个都有自己的通道)。我使用两个PNA-X的内部信号源和一个外部合路器为IM3创建双音信号 测量; DUT的LO由MXG外部馈电,我使用U2000A功率传感器执行源校准。 我尝试使用“Cal All Channels”校准所有3个通道。 但是,在校准完成并保存用户校准集后,显示屏上会弹出一条错误消息,说明(非逐字)校准中缺少错误条款。 一旦我清除了错误消息,我检查了可用的校准集,发现只保存了SMC +阶段通道的校准集; IM3和NF频道的校准集未保存。 我使用校准向导重复了IM3和NF通道的校准,并且令我惊讶的是,校准成功了! 为此,我前往每个测量通道并更改为端口1和2,然后再次尝试“Cal All Channels”; 校准成功(令我惊讶的是!)还有其他人遇到过这个问题吗? 任何建议/反馈将不胜感激! 以上来自于谷歌翻译 以下为原文 I have a 4-port N5241A (firmware updated to latest production release) that I'm using to test a duplex frequency converter. My analyzer is setup to measure SMC + phase, IMDx and NFX (each with its own channel) using ports 3 and 4. I'm using the two PNA-X's internal sources and an external combiner to create the two tone signal for the IM3 measurement; the LO for the DUT is being fed externally by a MXG and I'm using a U2000A power sensor to perform the source calibration. I attempted to calibrate all 3 channels using "Cal All Channels". However, after the calibration finished and I saved the user cal set, an error message popped up on the display stating (not verbatim) that error terms were missing from the calibration. Once I cleared the error message, I checked the available cal sets and found that only the cal set for the SMC + phase channel was saved; the cal sets for the IM3 and NF channels were not saved. I repeated the calibrations on the IM3 and NF channels using the Calibration Wizard and the calibrations, much to my surprise, were successful! In response to this, I went to each measurement channel and changed to ports 1 and 2 and then tried "Cal All Channels" again; the calibration was successful (again much to my surprise!) Has anyone else encountered this problem? Any advice/feedback would be greatly appreciated! |
你能发布一个方块图,说明你如何设置与PNA-X相关的外部组合(使用旧配置给你带来问题)?
在Cal All之前的原始设置的状态文件也非常有用。 谢谢 以上来自于谷歌翻译 以下为原文 can you post a block diagram of how you are setting up your external combining in relation to the PNA-X (with the old configuration that gave you problems)? also a state file of your original setup prior to Cal All would be very helpful. Thanks |
1335 浏览 0 评论
2397 浏览 1 评论
2218 浏览 1 评论
2086 浏览 5 评论
2976 浏览 3 评论
1240浏览 1评论
785浏览 0评论
1036浏览 0评论
1335浏览 0评论
GMT+8, 2025-1-14 05:25 , Processed in 1.127790 second(s), Total 46, Slave 40 queries .
