我在纠正离线DRC中发现的错误时遇到了错误。
它关闭了ADS,当我重新启动并尝试再次运行DRC时,它不会弹出结果查看器,让您自动缩放到错误。
我认为这是我正在使用的PDK,但它在带有演示套件的示例中做了同样的事情。
在DRC之后,它选择并突出显示所有错误,但我不知道它们在哪里,因为我看不到结果查看器。
我已卸载并重新安装ADS2012.08。
此时安装2013.06不是一个选项,因为我有一个迫在眉睫的截止日期,我不想改变任何东西。
还有其他人看到过这种情况吗?
以上来自于谷歌翻译
以下为原文
I had an error I think while correc
ting an error found in an off-grid DRC. It shut down ADS and when I restarted and tried to run DRC again it would not pop up the results viewer that lets you auto zoom to the error. I thought it was the PDK I was using but it does the same thing in an example with a demo kit. After DRC, it selects and highlights all the errors but I don't know specifically where they are because I cannot see the results viewer. I have uninstalled and reinstalled ADS2012.08. Installing 2013.06 is not an option at this point as I have an imminent deadline and I don't want to change anything.
Has anyone else seen this happen?
