嗨,PIC32 MZ2048 ECM/ECH处理器在旧的V1.XX和声框架中被支持,但是由于它们不被推荐用于新的设计,所以它们从和声V2.xx中被移除。补充。EX版本中存在的许多硅bug已经被固定在EFX版本中,如果你做了一个真正的项目,那么你就应该真正订购PIC32 MZ EF启动器套件。如果你只想“玩”与和谐,如果你不介意使用旧版本,那么下载V1.11。支持ECX部分。
以上来自于百度翻译
以下为原文
Hi,
The PIC32MZ2048ECM/ECH processors used to be supported in the old v1.xx Harmony framework but as they are not recommended for new designs, they have been removed from Harmony v2.xx.
The significant difference is the ADC which is completely different and the floating point processor which has been added. Lots of silicon bugs existing in ECx versions have been fixed in EFx versions
If you do a real project, then you should really order the PIC32MZ EF starter kit.
If you just want to "play" with Harmony and if you don't care to use an older version then download v1.11. which supports the ECx parts.
Regards
以上来自于百度翻译
以下为原文
Hi,
Regards
