梁咏琪:
我不得不问一个问题,我驱动电机为FOC无传感器,速度为30 - 162转,电机现在可以启动colse_loop,但由于关机,有时电机惯性,没有停机,那么如果马上启动,会启动失败,请问这种,还有在电机惯性,没有停止计时,然后启动。在这种情况下,该如何应对?最好的祝福
张学友
以上来自于谷歌翻译
以下为原文
Gigi:
I have to ask a ques
tion, I driver the motor for FOC sensorless, speed of 30 - 162 RPM, the motor can start colse_loop now, but because of the shutdown, and sometimes motor inertia, not stopped down, then if immediately start, will start failure, is excuse me this kind of, also has in the motor inertia, no stop timing, and then start. In this situation, how to deal with? Best Regards
Jacky
