@__daz__您只能使用您的登录生成一个webpack许可证,因此无法为另一台机器生成它。
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
以上来自于谷歌翻译
以下为原文
@__daz__ You can generate only one webpack license using your login hence no option to generate it for another machine.
-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
以上来自于谷歌翻译
以下为原文
-Pratham
