@maximp
您可以根据许可证文件中提到的版本限制使用Vivado / ISE工具,请参阅以下链接以获取更多详细信息:
http://www.xilinx.com/support/answers/33770.html
谢谢,Anusheel -----------------------------------------------
- - - - - - - - - - - - - - - - - - - - - - - - 搜索
在william hill官网
上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关william hill官网
并确保您的查询不会重复。请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助
回答 - >给予Kudos ---------------------------------------------
以上来自于谷歌翻译
以下为原文
@maximp
You can use the Vivado/ISE tools based on the version limit mentioned in the license file, refer below link for more details:
Thanks,
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
@maximp
在william hill官网
以上来自于谷歌翻译
以下为原文
@maximp
Thanks,
Anusheel
