> {quote:title = daras写道:} {quote}> 0.05 dB纹波实际上非常小,校准过程中电缆和/或电缆的移动很容易成为问题的根源。
Em,有趣的daras,你说+/- 0.05 dB很小,因为Joel表示我的S21纹波在+/- 0.02 dB处于良好的极限。
这看起来是否过度波动?
什么值得注意的?
我使用的设备比Dave_11要差一些,后者有PNA。
我有* 8720D VNA * 85032B N校准套件* Agilent 85131F VNA电缆,带3.5 mm到N的适配器。
(但我只工作到6 GHz,而不是8.5到11.5 GHz)使用我的8720D VNA,85052B 3.5 mm校准套件和Agilent 85131F VNA电缆,我似乎无法获得比+/- 0.02 dB更好的效果,
我试图尽可能保持。
事实上,0.02 dB似乎是一个好日子,但我通常可以做到+/- 0.05 dB。
我希望我能够更好地使用85052B中的滑动负载。
当我使用该套件作为光荣的85052D,这是原始海报(Dave_11)。
*(我很乐意看到安捷伦或Maury Microwave制作一些关于使用滑动载荷和验证套件的视频)*。
也许有滑动负载我可以做得更好。
戴夫
以上来自于谷歌翻译
以下为原文
> {quote:title=daras wrote:}{quote}
> 0.05 dB ripple is actually very small and bad cable and/or cable movement during calibration can easily be the source of the problem.
Em,
interesting daras that you say +/- 0.05 dB is small, since Joel indicated my S21 ripple at +/- 0.02 dB was on the limits of being good.
Does this look to be excessive ripple? What caues it?
I was using somewhat more antiquated equipment than Dave_11, who has a PNA. I had
* 8720D VNA
* 85032B N calibration kit
* Agilent 85131F VNA cables with 3.5 mm to N adapters.
(But I was only working up to 6 GHz, not 8.5 to 11.5 GHz)
I can't ever seem to get any better than about +/- 0.02 dB with my 8720D VNA, 85052B 3.5 mm cal kit and Agilent 85131F VNA cables, which I try to keep as still as possible. In fact, 0.02 dB seems a good day, but I can usually do better than +/- 0.05 dB.
I wish I was more confident of being able to use the sliding loads in my 85052B properly. At the minute I'm using the kit as a glorified 85052D, which is what the original poster (Dave_11) has. *(I would love to see Agilent or Maury Microwave produce some videos about using sliding loads and verification kits)*. Maybe with sliding loads I could do better.
Dave
这看起来是否过度波动?
什么值得注意的?
我试图尽可能保持。
也许有滑动负载我可以做得更好。
戴夫
以上来自于谷歌翻译
以下为原文
Em,
* 8720D VNA
Dave
