扫一扫,分享给好友
我是购买Vivado许可证的公司的分包商。
出于某种原因,我无法使用我的帐户信息激活许可证凭证。 有关我的帐户的哪些信息需要与我工作的公司匹配才能获得许可证凭证? -Jason 以上来自于谷歌翻译 以下为原文 I'm a sub-contractor to a company that purchased a Vivado license. For some reason I cannot activate the license voucher with my account information. What information about my account is required to match the company I work for in order to get the license voucher activated? -Jason |
3个回答
嗨@jmaranhao
您能否共享尝试激活许可证时遇到的确切错误消息? purchaselicense将添加到采购订单中提供的帐户中。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @jmaranhao Can you share the exact error message that you encounter when trying to activate the license? The purchased license will be added to the account that is provided in the purchase order. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
错误消息是“无效的优惠券代码。请重试。”
以上来自于谷歌翻译 以下为原文 The error message is "Invalid voucher code. Please try again." |
你好@ jmaranhao
查看此答复记录:http://www.xilinx.com/support/answers/45537.html 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @jmaranhao Check this answer record: http://www.xilinx.com/support/answers/45537.html Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1776浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 12:09 , Processed in 1.235242 second(s), Total 79, Slave 64 queries .
