我想知道是否可以将Vivado项目转换为ISE项目,以便将其导入HDL Designer。
HDL设计师确实有Vivado流,但不是Vivado导入。 或者,如果有人知道将vivado项目导入HDL Designer的步骤。 以上来自于谷歌翻译 以下为原文 I would like to know if it is possible to convert a Vivado project to an ISE project in order to import it into HDL Designer. HDL designer does have Vivado flows, but not a Vivado import. Or, if someone know the steps to import a vivado project into HDL Designer.. |
没有办法从Vivado项目转到ISE项目。
即使有这样的东西,它也只能用于7系列FPGA,因为这是唯一可以在两种工具下工作的系列。 Avrum 以上来自于谷歌翻译 以下为原文 There is no way to go from a Vivado project to an ISE project. Even if there were such a thing, it would only be useable for 7 Series FPGAs, since that is the only family that can work under both tools. Avrum |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2475 浏览 15 评论
1481浏览 1评论
601浏览 1评论
467浏览 1评论
2019浏览 0评论
741浏览 0评论
GMT+8, 2025-1-2 04:36 , Processed in 1.317489 second(s), Total 78, Slave 62 queries .
