你好:
我们在配置AD9854工作在ASK模式下,梯形可以正常输出,
矩形输出不了,按程序配置后输出的是正弦波。
给你发的程序UD_CLK都是外部更新的,内部更新的程序我也做了,效果和这个一样。
我们是用FPGA配置的,代码使用verilog实现。
麻烦看哈我是那个寄存器配置的有问题或者那不对,非常感谢。。。。谢谢。。
always @(posedge CLK)
if(RST)
mst_rst_cnt <= 8'h00;
else if(mst_rst_cnt == 8'h13)
mst_rst_cnt <= 8'h13;
else
mst_rst_cnt <= mst_rst_cnt + 1'b1;
always@(posedge CLK)
if(RST)
mst_rst<=1'b0;
else if(mst_rst_cnt >= 8'h01 && mst_rst_cnt <= 8'h12)
mst_rst<=1'b1;
else
mst_rst<=1'b0;
if(RST)
mst_rst_ok <= 1'b0;
else if(mst_rst_cnt > 8'h12)
mst_rst_ok <= 1'b1;
else;
reg [1:0] wrb_cnt;
if(RST)
wrb_cnt <= 2'b00;
else if(ad_9854_init_ok)
wrb_cnt <= 2'b00;
else if(mst_rst_ok)
wrb_cnt <= wrb_cnt + 1'b1;
else;
assign wrb = wrb_cnt[1];
if(RST)
ctrl_cnt <= 8'h0;
else if(mst_rst_ok)
if(ctrl_cnt == 8'd49)
ctrl_cnt <= 8'd49;
else if(wrb_cnt == 2'b00)
ctrl_cnt <= ctrl_cnt+ 1'b1;
else;
else;
if(RST)
io_ud <= 1'b0;
else if(ctrl_cnt== 8'd40)
io_ud <= 1'b1;
else if(ctrl_cnt== 8'd48)
io_ud <= 1'b0;
else;
if(RST)
ad_9854_init_ok <= 1'b0;
ad_9854_init_ok <= 1'b1;
else;
// --------------- 输出 AD_FSK_BPSK_HOLD 信号--------------------------
// 0 --- FTW1; 1 --- FTW2;
always@(posedge CLK) // 25M
if(RST)
fsk_div_cnt <= 16'h0;
if(fsk_div_cnt == SPEED_DELAY_CNT)
else
fsk_div_cnt <= fsk_div_cnt + 1'b1;
else
if(RST)
need_mod_out <= 1'b1;
else if(fsk_div_cnt > SPEED_DELAY_DIVID2)
else
need_mod_out <= 1'b0;
if(RST)
state <= 20'h0;
else
state <= state + 1'b1;
assign ask_out_range = 16'h0FF0;
assign AD_SHAPEDK = state[19];
// FSK F1 = 70.5M F2 = 69.5M
if(RST)
address <=6'b00_0000;
else if(mst_rst_ok)
case(ctrl_cnt)
// ************** 写寄存器 ***********************
// FTW1
8'd2 : address <= 6'b00_0100; //0x04 FTW1_5
8'd3 : address <= 6'b00_0101; //0x05 FTW1_4
8'd4 : address <= 6'b00_0110; //0x06 FTW1_3
8'd5 : address <= 6'b00_0111; //0x07 FTW1_2
8'd6 : address <= 6'b00_1000; //0x08 FTW1_1
8'd7 : address <= 6'b00_1001; //0x09 FTW1_0
// 输出幅度乘法器
8'd8 : address <= 6'b10_0001; //0x21
8'd9 : address <= 6'b10_0010; //0x22
8'd10 : address <= 6'b10_0011; //0x23
8'd11 : address <= 6'b10_0100; //0x24
// 写控制寄存器
8'd14 : address <= 6'b01_1101; //0x1D
8'd15 : address <= 6'b01_1110; //0x1E 配置PLL时钟
8'd16 : address <= 6'b01_1111; //0x1F
8'd17 : address <= 6'b10_0000; //0x20
// 输出边沿变化率控制器
//8'd19 : address <= 6'b10_0101; //0x25
default:address <= 6'b00_0000;
endcase
else;
if(RST)
data <=8'b1111_1011;
else if(mst_rst_ok)
case(ctrl_cnt)
// FTW1
8'd2 : data <= FTW1[47:40]; //0x04 FTW1_5
8'd3 : data <= FTW1[39:32]; //0x05 FTW1_4
8'd4 : data <= FTW1[31:24]; //0x06 FTW1_3
8'd5 : data <= FTW1[23:16]; //0x07 FTW1_2
8'd6 : data <= FTW1[15:8]; //0x08 FTW1_1
8'd7 : data <= FTW1[7:0]; //0x09 FTW1_0
// 输出幅度乘法器
8'd8 : data <= ask_out_range[15:8];//0x21
8'd9 : data <= ask_out_range[7:0]; //0x22
8'd10 : data <= 8'h0;//0x23
8'd11 : data <= 8'h0; //0x24
// 写控制寄存器 输出梯形的ASK调制模式
8'd14 : data <= 8'h10; //0x1D
8'd15 : data <= 8'h47; //0x1E 配置PLL时钟 280M
8'd16 : data <= 8'h00; //0x1F single tone 外部更新
8'd17 : data <= 8'h70; //0x20
// 输出边沿变化率控制器
//8'd19 : data <= 8'h03; //0x25
// OSK RAMP rate控制字来决定从0幅度到满幅度的转换时间,
// 控制子最小只能到0x03,再小就不能正常输出波形。
// 写控制寄存器 输出矩形的ASK调制模式
//8'd14 : data <= 8'h14; //0x1D
//8'd15 : data <= 8'h47; //0x1E 配置PLL时钟 280M
//8'd16 : data <= 8'h01; //0x1F single tone 外部更新
//8'd17 : data <= 8'h60; //0x20
default:data <= 8'h00;
endcase
else;
矩形输出不了,按程序配置后输出的是正弦波。(相同部分的程序就不贴了,矩形和梯形相比只是更改了0x20寄存器的配置)
if(RST)
else if(mst_rst_ok)
case(ctrl_cnt)
// FTW1
// 输出幅度乘法器
// 写控制寄存器
endcase
else;
if(RST)
else if(mst_rst_ok)
case(ctrl_cnt)
// FTW1
// 输出幅度乘法器
endcase
else;
