ARM技术william hill官网
兰凤送
6年用户 601经验值
擅长:电源/新能源 嵌入式技术 接口/总线/驱动
WIFI和3G移植手册
MY-I.MX6-DEMO Android4.4.2 WIFI和3G移植手册
移植WIFI(RTL8188EUS)
步骤一:
vim device/fsl/sabresd_6dq/BoardConfig.mk
# UNITE is a virtual device support both atheros and realtek wifi(ar6103 and rtl 8723as)
#BOARD_WLAN_DEVICE:            := UNITE
#WPA_SUPPLICANT_VERSION:         := VER_0_8_UNITE
#TARGET_KERNEL_MODULES:          :=   kernel_imx/drivers/net/wireless/rtl8723as/8723as.ko:system/lib/modules/8723as.ko
   kernel_imx/net/wireless/cfg80211.ko:system/lib/modules/cfg80211_realtek.ko
#BOARD_WPA_SUPPLICANT_DRIVER:      := NL80211
#BOARD_HOSTAPD_DRIVER:           := NL80211
#BOARD_HOSTAPD_PRIVATE_LIB_QCOM:           := lib_driver_cmd_qcwcn
#BOARD_WPA_SUPPLICANT_PRIVATE_LIB_QCOM:      := lib_driver_cmd_qcwcn
#BOARD_HOSTAPD_PRIVATE_LIB_RTL:           := lib_driver_cmd_rtl
#BOARD_WPA_SUPPLICANT_PRIVATE_LIB_RTL
BOARD_WIFI_VENDOR := realtek
BOARD_WLAN_VENDOR := REALTEK
ifeq ($(BOARD_WIFI_VENDOR),realtek)
WPA_SUPPLICANT_VERSION :=VER_0_8_X
BOARD_WPA_SUPPLICANT_DRIVER :=NL80211
#CONFIG_DRIVER_WEXT :=y
CONFIG_DRIVER_NL80211 :=true
BOARD_WPA_SUPPLICANT_PRIVATE_LIB:= lib_driver_cmd_rtl
BOARD_HOSTAPD_DRIVER := NL80211
BOARD_HOSTAPD_PRIVATE_LIB :=lib_driver_cmd_rtl
BOARD_WLAN_DEVICE := rtl8192cu
#BOARD_WLAN_DEVICE := rtl8192du
#BOARD_WLAN_DEVICE := rtl8192ce
#BOARD_WLAN_DEVICE := rtl8192de
#BOARD_WLAN_DEVICE := rtl8723as
#BOARD_WLAN_DEVICE := rtl8723au
#BOARD_WLAN_DEVICE := rtl8189es
#BOARD_WLAN_DEVICE := rtl8723bs
#BOARD_WLAN_DEVICE := rtl8723bu
WIFI_DRIVER_MODULE_NAME :="wlan"
WIFI_DRIVER_MODULE_PATH := "/system/lib/modules/wlan.ko"
WIFI_DRIVER_MODULE_ARG :="ifname=wlan0 if2name=p2p0"
WIFI_FIRMWARE_LOADER :=""
WIFI_DRIVER_FW_PATH_STA :=""
WIFI_DRIVER_FW_PATH_AP :=""
WIFI_DRIVER_FW_PATH_P2P :=""
WIFI_DRIVER_FW_PATH_PARAM :=""
Endif
步骤二:
vim device/fsl/sabresd_6dq/init.rc
#service p2p_supplicant /system/bin/wpa_supplicant
# -ip2p0 -Dnl80211 -c/data/misc/wifi/p2p_supplicant.conf
# -I/system/etc/wifi/p2p_supplicant_overlay.conf -N
# -iwlan0 -Dnl80211 -c/data/misc/wifi/wpa_supplicant.conf
# -I/system/etc/wifi/wpa_supplicant_overlay.conf
# -O/data/misc/wifi/sockets -puse_p2p_group_interface=1
# -e/data/misc/wifi/entropy.bin -g@android:wpa_wlan0
# class late_start
# socket wpa_wlan0 dgram 660 wifi wifi
# disabled
# oneshot
#service rtw_suppl_con /system/bin/rtl_wpa_supplicant
# class late_start
# disabled
# oneshot
service rtw_suppl_con /system/bin/wpa_supplicant
  -e/data/misc/wifi/entropy.bin -N
  class main
  disabled
  oneshot
service rtw_suppl /system/bin/wpa_supplicant
  class main
  disabled
  oneshot
步骤三:
”realtek_wifi_SDK_for_android_KK_4.4_20140117.tar.gz” 解压,然后将里面的ANDROID_SDK/hardware/realtek覆盖到android源码hardwar/realtek目录下中。
步骤四:
vim hardware/libhardware_legacy/wifi/Android.mk
#ifeq ($(BOARD_WLAN_DEVICE),UNITE)
# LOCAL_C_INCLUDES += $(LOCAL_PATH)/../../external/wpa_supplicant_ath/wpa_supplicant/src/common
# LOCAL_SRC_FILES += wifi/wifi_unite.c
#else ifeq ($(BOARD_WLAN_VENDOR), INTEL)
# LOCAL_SRC_FILES += wifi/wifi_intel.c
# LOCAL_C_INCLUDES += $(LOCAL_PATH)/../../external/wpa_supplicant_8/src/common
#else
# LOCAL_SRC_FILES += wifi/wifi.c
#endif
LOCAL_SRC_FILES +=../realtek/wlan/libhardware_legacy/wifi/wifi_realtek.c
else
endif
步骤五:
将android源码的external/下wpa_supplicant_8备份一下,然后将驱动包里的wpa_supplicant_8_kk_4.4_rtw_r10450.20140220.tar.gz解压并重命名为wpa_supplicant_8并替换到我们android的external/目录下。
步骤六:
修改文件kernel_imx/arch/arm/configs/imx6_android_defconfig,(或者修改.config)将下列项目配置成Y.
CONFIG_CFG80211=y
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211=y
CONFIG_HOSTAP=y
CONFIG_USB_USBNET=y
步骤七:
vim device/fsl/imx6/etc/init.rc
 setprop wifi.interface wlan0
 setprop wlan.driver.status "ok"
步骤八:
out/target/product/sabresd_6dq下的system文件夹以及out/target/product/sabresd_6d/obj/EXECUTABLES下wpa_supplicant_intermediates文件夹删除,重新编译system.img和boot.img。
步骤九:
编译wlan.ko复制system/lib/modules/目录下
vim Makefile
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_NEW = y
ifeq ($(CONFIG_PLATFORM_NEW), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN
ARCH := arm
CROSS_COMPILE :=/home/linyn/android/android-myzr/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi- KSRC := /home/linyn/android/android-myzr/kernel_imx
MODULE_NAME := wlan
endif
vim include/autoconf.h
#define CONFIG_IOCTL_CFG80211
#ifdef CONFIG_IOCTL_CFG80211
#define RTW_USE_CFG80211_STA_EVENT
//#defineCONFIG_CFG80211_FORCE_COMPAtiBLE_2_6_37_UNDER
//#define CONFIG_DEBUG_CFG80211 1
#endif
#define CONFIG_CONCURRENT_MODE
#define CONFIG_P2P_IPS
最后编译成wlan.ko复制到system/lib/modules/目录下
移植3G(MU609)
步骤一:
vim kernel_imx/drivers/u***/serial/option.c
#define HUAWEI_PRODUCT_E353:   0x1506
改为
#define HUAWEI_PRODUCT_E353:   0x1573
步骤二:
vim hardware/ril/rild/rild.c
#define REFERENCE_RIL_DEF_PATH "/system/lib/libreference-ril.so"
改为
#define REFERENCE_RIL_DEF_PATH "/system/lib/libhuawei-ril.so"
// switchUser();
步骤三:
Vim hardware/ril/runtime-ril-port/runtime_port.c
在数组里增加新的结构:
static struct modem_3g_device modem_3g_device_table[] = {
  .name:  = "Huawei-MU609",
  .idVendor = "12d1",
  .idProduct = "1573",
  .deviceport = "/dev/ttyUSB2",
  .dataport = "/dev/ttyUSB0",
  .type:  = HUAWEI_MODEM,
步骤四:
复制 ip-up,ip-down 到 /system/etc/ppp目录下,复制 libhuawei-ril.so 到 /system/lib目录下。
步骤五:
按照以下修改:
chmod 777 /dev/ttyUSB0
chmod 777 /dev/ttyUSB2
chmod 777 /etc/ppp/ip-up
chmod 777 /etc/ppp/ip-down
#service ril-daemon /system/bin/rild
service ril-daemon /system/bin/rild -l /system/lib/libhuawei-ril.so
步骤六:
回帖(1)
杨义
2018-12-30 22:20:10
学习了
