我认为另一个问题是我最初安装了Xilinx 14.7 ISE Suite Web Pack。
Web Pack不包括System Generator,对吧?
我卸载了与Xilinx相关的所有内容并安装了ISE Design Suite System Edition。
其中一个弹出窗口说“System Generator目前对[MATLAB]版本R2016b有Beta支持。”
这是正常的吗?
最后,我仍然收到一条错误,上面写着“无法打开用于编写C: Program Files MATLAB R2016b / toolbox / local / classpath.txt.tmp的临时文件。目录可能存在权限问题。”
我注意到的一件事是使用了正斜杠和反斜杠。
该脚本可能混合了Linux和Windows目录链接分配?
您能否推荐一个更好的位置来安装ISE Design Suite?
在C:驱动器而不是Program Files目录?
请参阅附注为PDF文件的注释。
20170630新安装的ISE 14.7.pdf 191 KB
以上来自于谷歌翻译
以下为原文
Another problem I think is that I originally had Xilinx 14.7 ISE Suite Web Pack installed.
Web Pack does not include System Generator, right?
I uninstalled everything related to Xilinx and installed ISE Design Suite System Edition.
One of the pop-up windows said "System Generator currently has Beta support for [MATLAB] version R2016b."
Is this normal?
At the end, I still got an error that said "Failed to open temporary file for writing C:Program FilesMATLABR2016b/toolbox/local/classpath.txt.tmp. Possible permission problems with directory."
One thing I notice is that both front-slash and back-slash are used. The script may be mixing up Linux and Windows directory link assignments?
Can you recommend a better location to install ISE Design Suite?
On the C: drive and not the Program Files directory?
See notes attached as a PDF file.
20170630 new installation of ISE 14.7.pdf 191 KB
这是正常的吗?
请参阅附注为PDF文件的注释。
以上来自于谷歌翻译
以下为原文
Is this normal?
