赛灵思
张奕
7年用户 204经验值
Matlab2013a,ISE14.7,Xilinx分频器,Xi​​linx模块库中发生内部错误
您好我使用matlab 2013a和ISE 14.7开发我的模型以在dSpace MicroAutboxII中运行。
我可以使用库中的每个xilinx块,但是当我使用Xilinx Divider时,会出现错误“Xilinx Blockset Library中发生内部错误”
会出现什么问题?
我尝试做一些我在这个william hill官网 上阅读的选项,比如切换许可证文件,但我没有帮助。
---------------------------------版本日志---------------
------------------- Version PathSystem Generator C:/Xilinx/14.7/ISE_DS/ISE/sysgenMatlab 8.1.0.604(R2013a)C:/ Program Files / MATLAB / R2013aISE C
:/Xilinx/14.7/ISE_DS/ISE -----------------------------------------
---------------------------------------错误摘要:错误0001:内部错误块:
'DIVIDE02 / Divide1' ---------------------------------------------
错误0001:
报告人:'DIVIDE02 / Divide1'
详细信息:Xilinx模块库中发生内部错误。
DIVIDE02.slx 21 KB
以上来自于谷歌翻译
以下为原文
Hello I am using Matlab 2013a and ISE 14.7 to develop my models to run in a dSpace MicroAutboxII.
I can use every xilinx block in the library but when i use Xilinx Divider, a get the error "An internal error occurred in the Xilinx Blockset Library"
What would be the problem?
I tried to do some options that I read on this forum like switching the license file but i doesn't help.
--------------------------------- Version Log ----------------------------------
Version Path
Matlab 8.1.0.604 (R2013a) C:/Program Files/MATLAB/R2013a
ISE C:/Xilinx/14.7/ISE_DS/ISE
Summary of Errors:
Error 0001: Internal Error
Block: 'DIVIDE02/Divide1'
Error 0001:
Reported by:
'DIVIDE02/Divide1'
Details:
An internal error occurred in the Xilinx Blockset Library.
            DIVIDE02.slx ‏21 KB
回帖(2)
刘溪
2018-12-27 11:14:16
你好
尝试以下AR中的建议
https://www.xilinx.com/support/answers/44617.html
问候,萨蒂什-----------------------------------------------
--- --------------------------------------------请注意
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.--
以上来自于谷歌翻译
以下为原文
Hi
Try suggestions in below AR
Regards,
Satish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
李铃华
2018-12-27 11:29:13
检查这些ARs这是他们需要遵循工具兼容性的主ARs https://www.xilinx.com/support/answers/55830.html查看这些答案记录:http://www.xilinx.com/support/answers/
41563.htmlhttp://www.xilinx.com/support/answers/44617.htmlhttp://www.xilinx.com/support/answers/33770.html
谢谢和RegardsBalkrishan -----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
check these ARs
This is the master ARs which they require to follow for tool compatibility
Check these answer record:
http://www.xilinx.com/support/answers/41563.html
Thanks and Regards
Balkrishan
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
