嗨,大家好,
我需要为一个PSoC 4模块写一个RS485引导加载程序,我想知道是否有可能在没有“定制”任何东西的情况下做到这一点。事实上,在PSoC 4中使用“Bootloader”组件与UDB UART导致不正确的引导加载,但是使用SCB UART,RS485通信似乎并不直接实现(在UDB上,您拥有有用的“硬件TX使能”特性)。我正在测试通过使用“UART Bootloader主机应用程序”从AN6262在CY8CITK-042-BLE先驱与PSoC 4 BLE模块通过USB和每个引导加载尝试导致“BootLoad失败与错误代码:0x000”A。使用相同配置的SCB引导加载工作良好。我应该编写自己的引导加载程序还是我正在使用的组件、模块和软件出错? 我已经附加了工作区。 谢谢您! 西蒙尼 BooLoad 1.7兆字节 以上来自于百度翻译 以下为原文 Hi all, I need to write a Rs485 bootloader application for PSOC 4 module and I would like to know if it is possible to do that without "customizing" anything. In fact seems that using "Bootloader" component with UDB UART in PSOC 4 leads to uncorrect bootloading but with SCB UART an RS485 communication seems to be not straightforward to implement (on UDB you have the useful "Hardware TX Enable" feature). I'm testing the application using "UART Bootloader Host Application" from AN68272 on CY8CKIT-042-BLE Pioneer with PSOC 4 BLE Module through USB and every bootloading attempt leads to " Bootload Failed with Error Code: 0x0000A". SCB bootloading with the same configuration is working well. Am I supposed to write my own bootloader or am I doing something wrong with the components, modules and softwares that I'm using? I've attached the workspace. Thank you! Simone |
4个回答
嗨,出于兴趣,你用PS484的RS485连接解决了这个问题吗? 当做 格雷戈 以上来自于百度翻译 以下为原文 Hi, out of interest did you resolve the issue with the RS485 connections to the PSoC4? Regards Greg |
你也需要考虑到RS485的电压电平差异。 以上来自于百度翻译 以下为原文 You would also need to take into account the voltage level differences for the RS485 as well. |
只是出于好奇,因为我使用的SN65 HV1752与同一PSoC接口,在921600 -看起来像线程发起人错过了TXEN连接到485收发器的设计-猜这个线程是休眠的。 以上来自于百度翻译 以下为原文 Just a question out of curiosity as i am using a SN65HV1782 for interfacing with the same PSoC, at 921600 - looked like the thread initiator missed the TXEN connection to the 485 transceiver in the design - guess this thread is dormant |
是的,你可能已经死了; 尝试打开一个新的线程/问题,如果你仍然有麻烦,找出设置。 以上来自于百度翻译 以下为原文 Yeah; You might have necroed the post ;P Try opening a new thread/question if you are still having trouble figuring out the setup. |
756个成员聚集在这个小组
加入小组2125 浏览 1 评论
1867 浏览 1 评论
3683 浏览 1 评论
1803 浏览 6 评论
1550 浏览 1 评论
613浏览 2评论
456浏览 2评论
451浏览 2评论
403浏览 2评论
1089浏览 2评论
GMT+8, 2025-1-14 18:46 , Processed in 1.023410 second(s), Total 81, Slave 65 queries .
