你好@ akosaraj5,
您可能已经安装了Vivado Lab Edition而不是Vivado System或Design(或WebPACK)版本。
您可以导航到例如C: Users \。Xilinx xinstall和最新的xinstall_1234567890xxx.log文件,在这里您可以看到安装了哪个版本,例如:
你能仔细检查一下吗?
亲切的问候,Anatoli Curran,Xilinx技术支持-----------------------------------------
--------------------------------不要忘记回复,工作,并接受解决方案.----
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello @akosaraj5,
It looks like you may have installed Vivado Lab Edition instead of Vivado System or Design (or WebPACK) edition.
You can navigate to e.g. C:Users
.Xilinxxinstall and in the latest xinstall_1234567890xxx.log file, in here you can see what edition was installed, e.g.:
Can you double check this please?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Don’t forget to reply, kudo, and accept as solution.
-------------------------------------------------------------------------View solution in original post
你好@ akosaraj5,
你能仔细检查一下吗?
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello @akosaraj5,
Kind Regards,
Anatoli Curran,
