赛灵思
刘嘉佳
7年用户 138经验值
从vivado gui启动时找不到show sdk
嗨朋友们,
已安装SDK,但是从vivado gui启动时,找不到show sdk。
我有疑虑。
1)当我点击launch_sdk fron vivado GUI时,vivado会考虑什么路径?
2)如何设置此SDK路径,从vivado打开sdk?
谢谢
S Sampath
以上来自于谷歌翻译
以下为原文
Hi Friends,
SDK installed , but while launching from vivado gui it was show sdk not found.  I have following doubts.
1) What path vivado consider when i click launch_sdk fron vivado GUI ?
2) how to set this SDK path, to open the sdk from the vivado ?
Thank You
S Sampath
回帖(6)
姚庭芳
2019-1-2 15:21:43
你好@ ssampath
请按照以下步骤告诉我它是否有效:1。通过从命令行2执行C: Xilinx  Vivado  2017.4  settings64.bat来设置Vivado 2017.4所需的环境变量。
通过从命令行3执行C: Xilinx  SDK  2017.4  settings64.bat来设置SDK 2017.4所需的环境变量。
打开Vivado 2017.4项目;
生成比特流;
并将项目导出到SDK
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi @ssampath
Follow these steps and let me know if it works:
1. Set-up the environment variables required for Vivado 2017.4 by executing C:XilinxVivado2017.4settings64.bat from command line
2. Set-up the environment variables required for SDK 2017.4 by executing C:XilinxSDK2017.4settings64.bat from command line
3. Open the Vivado 2017.4 project; generate bitstream; and, export the project to SDK
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
周蕊
2019-1-2 15:40:46
我正在使用Linux服务器,太版本2016.4。
对于linux也一样吗?
以上来自于谷歌翻译
以下为原文
I am using Linux server , that too version 2016.4 . is it same for linux also ?
姚庭芳
2019-1-2 16:00:40
嗨Sampath,对于linux,请使用Vivado安装目录中的settings64.sh或settings64.csh(取决于您使用的shell)。谢谢,Vinay
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hi Sampath,
For linux, use settings64.sh or settings64.csh (depends on the shell you use) from the Vivado installation directory.
Thanks,
Vinay--------------------------------------------------------------------------------------------
周蕊
2019-1-2 16:06:27
我正在使用tcsh,所以这个setting.sh文件已经足够了吗?
以上来自于谷歌翻译
以下为原文
i am using tcsh , so souring this setting.sh file is enough ?
