扫一扫,分享给好友
嗨,
我们有Vivado的系统版许可证,但在使用'xcku040'合成时会显示以下失败消息。 它适用于Artix部分,但不适用于我们想要的'xcku040'部分。 你能帮帮我吗? [Common 17-345]找不到功能'Synthesis'和/或设备'xcku040'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 如果您使用的是许可证服务器,请验证许可证服务器是否已启动并运行与您正在使用的Xilinx软件版本兼容的xilinx守护程序版本。 请注意,Vivado 2017.3及更高版本需要将许可证服务器工具升级到Flex 11.14.1工具。 请与您的许可证管理员确认已安装正确版本的许可证服务器工具。 以上来自于谷歌翻译 以下为原文 Hi, We have a system edition license for Vivado, but it shows the following fail message when synthesised with 'xcku040'. It works with Artix part, but not the 'xcku040' part we wanted. Could you please help me with this? [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xcku040'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". If you are using a license server, verify that the license server is up and running a version of the xilinx daemon that is compatible with the version of Xilinx software that you are using. Please note that Vivado 2017.3 and later requires upgrading your license server tools to the Flex 11.14.1 tools. Please confirm with your license admin that the correct version of the license server tools are installed. |
4个回答
嗨@chaooxford,
Vivado 2018.1要求许可证版本限制为2018.04,您的许可证的版本限制为2018.02,因此许可证不兼容。 要么需要通过营销代表升级许可证,要么需要使用Vivado 2017.4。 请参阅下面的许可证版本限制图表。 https://www.xilinx.com/support/answers/33770.html 谢谢你,德文 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @chaooxford, Vivado 2018.1 requires a license version limit of 2018.04, your license has a version limit of 2018.02 therefore the license is not compatible. Either the license would need to be upgraded via your marketing rep or Vivado 2017.4 would need to be used instead. Please see the license version limit chart below. https://www.xilinx.com/support/answers/33770.html Thank you, Devin View solution in original post |
嗨@chaooxford,
您选择的Kintex US部分未包含在webpack中,需要工具许可证。 您可以通过发布说明https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug973-vivado-release-notes-install-license.pdf的第18页上的webpack工具查看支持哪些部分。 现在,您的VLM确实显示您拥有工具许可证,但此版本限制2018.02与您使用的工具版本不兼容。 请参阅版本限制图表https://www.xilinx.com/support/answers/33770.html。 您当前的许可证适用于Vivado版本2017.4.1及之前版本。 谢谢你,德文 以上来自于谷歌翻译 以下为原文 Hi @chaooxford, The Kintex US part you are selecting is not covered in the webpack and requires a tools license. You can see which parts are supported via the webpack tool on page 18 of the release notes https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug973-vivado-release-notes-install-license.pdf. Now your VLM does show you do have a tools license however this version limit of 2018.02 is not compatible with the tools version you are using. Please see the version limit chart https://www.xilinx.com/support/answers/33770.html. Your current license will work with Vivado versions 2017.4.1 and prior. Thank you, Devin |
嗨devinl,
我们拥有Vivado设计版的完整许可,而不是webpack。 我正在使用2018.1,这应该没问题。 我不明白为什么会这样。 最好的祝福, 超 以上来自于谷歌翻译 以下为原文 Hi devinl, We have the the full license for Vivado design edition, not the webpack. And I am using 2018.1, which should be OK. I do not understand why this happened. Best regards, Chao |
嗨@chaooxford,
Vivado 2018.1要求许可证版本限制为2018.04,您的许可证的版本限制为2018.02,因此许可证不兼容。 要么需要通过营销代表升级许可证,要么需要使用Vivado 2017.4。 请参阅下面的许可证版本限制图表。 https://www.xilinx.com/support/answers/33770.html 谢谢你,德文 以上来自于谷歌翻译 以下为原文 Hi @chaooxford, Vivado 2018.1 requires a license version limit of 2018.04, your license has a version limit of 2018.02 therefore the license is not compatible. Either the license would need to be upgraded via your marketing rep or Vivado 2017.4 would need to be used instead. Please see the license version limit chart below. https://www.xilinx.com/support/answers/33770.html Thank you, Devin |
2731 浏览 7 评论
3046 浏览 4 评论
2463 浏览 9 评论
3574 浏览 0 评论
2668 浏览 15 评论
3480浏览 1评论
886浏览 1评论
731浏览 1评论
GMT+8, 2025-8-6 08:05 , Processed in 0.490970 second(s), Total 46, Slave 41 queries .
