赛灵思
谭怡宁
7年用户 186经验值
安装SDx 2017.2时无法安装System Generator
当我完成SDx 2017.2的安装时,没有安装System Generator的选项。
我正在运行从Xilinx下载的安装程序:https://www.xilinx.com/member/forms/download/xef.html?filename = Xilinx_SDx_2017.2_sdx_0823_1.tar.gz
安装程序的文档将安装Vivado Design Suite System Edition,但没有安装System Generator的选项(见下图)。
如何安装System Generator?
我需要使用其他安装程序吗?
以上来自于谷歌翻译
以下为原文
When I run through the installation for SDx 2017.2, there are no options to install System Generator.
I'm running the installer downloaded from Xilinx here: https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_SDx_2017.2_sdx_0823_1.tar.gz
The documentation for the installer states that it will be installing Vivado Design Suite System Edition, but there are no options to install System Generator (see image below).
How can I install System Generator? Do I need to use a different installer?
回帖(10)
张林锋
2019-1-7 11:07:19
你好@ wpunchak
我已与开发团队确认,当2017.2 SDx发布时,它仍然是单独的,我们从2017年开始整合SDx + Vivado.3内部和2017.4生产。
什么包含在2017.2中SDx由营销定义,从我们看到,它包括SDx所依赖的工具,如Vivado,SDK和HLS,在GUI中显示为“Vivado”预选,不允许用户取消选择它
,因为所有这些都需要运行SDx。
Sysgen不是它的一部分,因为SDx在没有Sysgen的情况下运行良好。
即使对于Vivado系统版,Sysgen也是一个单独的选项,默认选择,但用户可以取消选择它,因此它不是System Edition必须的。
如果您想使用SysGen v2017.2,则需要下载并安装2017.2 Vivado而不是2017.2 SDx。
或者您可以使用较新版本的SDx  -  2017.4或以上版本是组合的SDx + Vivado图像,Sysgen作为单独的选项包含在内,默认情况下未经营销决策选择。
例如。:
希望以上是清楚的。
亲切的问候,Anatoli Curran,Xilinx技术支持-----------------------------------------
--------------------------------不要忘记回复,工作,并接受解决方案.----
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello @wpunchak
I have confirmed with the developement team that when 2017.2 SDx was released, it still was by itself, we have the combined SDx + Vivado starting from 2017.3 Internal and 2017.4 Production. What’s included in 2017.2 SDx was defined by marketing, from what we see, it included the tools that SDx depends on, like Vivado, SDK and HLS , showing in GUI as “Vivado” pre-selected and does not allow user to de-select it, as all these are required to run SDx. Sysgen is not part of it, as SDx works well without Sysgen. Even for the Vivado System Edition, Sysgen is a separate option, just by default selected but user can de-select it, so it’s not a must for System Edition.
If you want to use SysGen v2017.2, you'd need to download and install the 2017.2 Vivado instead of the 2017.2 SDx. Or you can move to use the newer version of SDx -- 2017.4 or the above versions are the combined SDx + Vivado image, Sysgen is included as a separate option, by default not selected though with the marketing decision.
e.g.:
Hope the above is clear.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Don’t forget to reply, kudo, and accept as solution.
-------------------------------------------------------------------------View solution in original post
张林锋
2019-1-7 11:13:28
你好@ wpunchak,
从下面的链接中可以看到,System Generator for DSP是Vivado®HL系统版的一部分,而不是SDx的一部分。
https://www.xilinx.com/products/design-tools/vivado/integration/sysgen.html#buy
从Vivado安装GUI,您还可以看到此注释:
请注意,SysGen与Vivado System Edition安装一起安装。
选择要安装的Vivado系统版本后,在下一个安装窗口中没有选项(类似于SDK)来选择/取消选择SysGen。
但是,一旦安装了Vivado System Edition,就可以在开始菜单下找到System Generator,例如:
希望这可以帮助。
以上来自于谷歌翻译
以下为原文
Hello @wpunchak,
From the below link you can read that System Generator for DSP is part of the Vivado® HL System Edition and not of the SDx.
From the Vivado install GUI you can also see this note:
Please note that SysGen gets installed together with the Vivado System Edition installation. There won't be an option (similar to SDK) to select/unselect SysGen on the next installation window after you've selected the Vivado System edition to be installed.
However, once the Vivado System Edition is installed, under the start menu you'd then be able to find System Generator, e.g.:
Hope this helps.
Kind Regards,
Anatoli Curran,
黎菁菁
2019-1-7 11:24:15
谢谢@ anatoli,但我仍然对Xilinx产品的不同之处感到困惑。
从2017.2 SDx的文档中可以看出:
SDSoC™的安装包括以下内容:
•SDSoC环境,包括基于Eclipse / CDT的GUI,高级系统编译器和
ARM GNU工具链
•Vivado®DesignSuite系统版,带有Vivado高级综合(HLS)和
Xilinx®软件开发套件(SDK)您能否澄清一下安装了SDx的Vivado Design Suite系统版和独立的Vivado HL系统版之间的区别?
SDx安装是否仅安装部分Vivado Design Suite系统版?
与2017.2 SDx一起安装的Vivado Design Suite系统版不包括System Generator。
以上来自于谷歌翻译
以下为原文
Thanks @anatoli, but I'm still confused about where Xilinx products differ.
From the documentation for the 2017.2 SDx it states:
The installation of SDSoC™ includes the following:• SDSoC environment, including an Eclipse/CDT-based GUI, high-level system compiler, andARM GNU toolchain• Vivado® Design Suite System Edition, with Vivado High-Level Synthesis (HLS) and theXilinx® Software Development Kit (SDK)Could you clarify what is different between the Vivado Design Suite System Edition installed with the SDx and the standalone Vivado HL System Edition?
Does the SDx installation install only a partial Vivado Design Suite System Edition?
The Vivado Design Suite System Edition installed with the 2017.2 SDx does not include the System Generator.
张林锋
2019-1-7 11:37:54
你好@ wpunchak,
为这种困惑道歉。
当我们谈论Vivado系统版时,如果安装了这个版本,无论是通过“独立”Vivado Design Suite安装还是SDx安装完成,SysGen都是此安装的一部分。
如果您没有SysGen,请将其视为Vivado Design Edition,因为Vivado System Edition是VivadoDesign Edition + SysGen for DSP的超集。
运行SDx xsetup安装程序将获得与2017.2 Vivado xsetup安装程序相同的Vivado Design Suite,并提供与Vivado System Edition安装相同的选项。
SDx xsetup安装程序是Vivado System Edition版本的超集。
BTW,FYI  - 安装Vivado System Edition后,您只需要一个VivadoSystem Edition许可证。
安装SDX后,您需要VivadoSystem Edition许可证+ SDSoC许可证。
希望以上是清楚的。
以上来自于谷歌翻译
以下为原文
Hello @wpunchak,
Apologies for the confusion.
When we are talking about Vivado System Edition, if this is installed, no matter if this is done via "stand alone" Vivado Design Suite installation or SDx installation, SysGen comes as part of this installation. If you have no SysGen, consider this to be Vivado Design Edition, as Vivado System Edition is a superset of Vivado Design Edition + SysGen for DSP.
Running the SDx xsetup installer would get you the same Vivado Design Suite as the 2017.2 Vivado xsetup installer, and offers the same options as the Vivado System Edition installation. The SDx xsetup installer is a super-set of the Vivado System Edition version.
BTW, FYI -  when having Vivado System Edition installed, you'd just need a Vivado System Edition license.
Having SDx installed, you'd need a Vivado System Edition license + SDSoC license.
Kind Regards,
Anatoli Curran,
