Hi All, I have a design issue, I have an interface between two domains: Input is a 16 bit parallel data at 50MHz Output is 1 bit serial data at 500 MHz, For this scenario, I need to design a FIFO. Can anyone help me with the FIFO design, especially the minimun FIFO depth? Also I wnated to know if my input changes to a burst of 3 data units(16 bits each), what should be the depth? Thanks, Arun |
