你好!
我是FPGA设计的新手。 我想在我的项目中使用DCM,但是,在我执行Xilinx时钟向导之后,没有生成响应的vhdl文件。 我想知道我该怎么生成这个vhdl文件。 我还有其他步骤吗? 谢谢你的考虑! 以上来自于谷歌翻译 以下为原文 Hello!I am sort of new to FPGA Design. I want to use DCM in my project, however,after I do after Xilinx Clocking Wizard, there is no responding vhdl file generated. I want to know what should I to generate this vhdl file. Is there any other steps I do not do yet? thank you for your consideraion! |
3个回答
yuanran写道:您好!
我是FPGA设计的新手。 我想在我的项目中使用DCM,但是,在我执行Xilinx时钟向导之后,没有生成响应的vhdl文件。 我想知道我该怎么生成这个vhdl文件。 我还有其他步骤吗? 谢谢你的考虑! 不要使用时钟向导。 从库中实例化DCM和支持缓冲区。 你是新手,所以越早学会不依赖任何Xilinx提供的IP或“向导”,就越好。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 yuanran wrote:Don't use the clocking wizard. Instantiate the DCM and the supporting buffers from the library. You're new, so the sooner you learn to not rely on any Xilinx-provided IP or "Wizard," the better. ----------------------------Yes, I do this for a living. |
检查项目设置以查看是否启用HDL输出以及设置输出目录的位置。
我最近遇到类似的问题,当我开始coregen,打开一个以前保存的项目,生成一个新的核心,关闭coregen然后找不到输出。 我打开的项目已将输出目录设置为我不在的那个,在我更改到正确的目录后,新的输出文件是正确的,我告诉coregen放置它们。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Check your project settings to see if you enable the HDL output as well as where you set the output directory. I came across a similar issue recently when I started coregen, opened a previously saved project, generated a new core, closed coregen and then couldn't find the output. The project that I opened had set the output directory set to one that I wasn't in and after I changed to the correct directory the new output files were right were they where I told coregen to put them. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
谢谢你,先生!
我已经解决了这些问题。 但我不知道为什么。 我唯一要做的就是删除所有文件并重新添加它们。 然后一切都很好。 疯! 哈哈 以上来自于谷歌翻译 以下为原文 Thank you,Sir! I have solved the problems. But I do not know why. the only thing I do is to remove all the file and add them again. then everything goes fine. Crazy! haha |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1775浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 11:11 , Processed in 0.684794 second(s), Total 77, Slave 61 queries .
