烧录部分的log:
°IrtWiQ??from SD card...
reading u-boot.bin
reading u-boot.bin
I2C: ready
DRAM: 512 MiB
NAND: 1024 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Net: Could not get PHY for cpsw: addr 0
cpsw, u***_ether
##### EmbedSky BIOS for TQ3358 #####
This Board: DRAM:512MB,NAND:1024MB.LCD display size is: 800X480.
Hit any key to stop autoboot: 0
reading imagesEmbedSky.ini
634 bytes read in 6 ms (102.5 KiB/s)
bootloader=u-boot.bin
reading MLO
82148 bytes read in 14 ms (5.6 MiB/s)
NAND erase.part: device 0 offset 0x0, size 0x40000
Erasing at 0x0 -- 100% complete.
OK
NAND write: device 0 offset 0x0, size 0x140e4
Writting at 0x140e4 -- 100% complete.
82148 bytes written: OK
reading u-boot.bin
561904 bytes read in 68 ms (7.9 MiB/s)
NAND erase.part: device 0 offset 0x100000, size 0x100000
Erasing at 0x1c0000 -- 100% complete.
OK
NAND write: device 0 offset 0x100000, size 0x892f0
Writting at 0x1892f0 -- 100% complete.
561904 bytes written: OK
logodir=images\BZlogo.bin
reading imagesBZlogo.bin
1536000 bytes read in 167 ms (8.8 MiB/s)
NAND erase.part: device 0 offset 0x280000, size 0x500000
Erasing at 0x740000 -- 100% complete.
OK
NAND write: device 0 offset 0x280000, size 0x177000
Writting at 0x3f7000 -- 100% complete.
1536000 bytes written: OK
Linux uImage=images\zImage.bin
reading imageszImage.bin
3662600 bytes read in 393 ms (8.9 MiB/s)
NAND erase.part: device 0 offset 0x780000, size 0x500000
Erasing at 0xc40000 -- 100% complete.
OK
NAND write: device 0 offset 0x780000, size 0x37e308
Writting at 0xafe308 -- 100% complete.
3662600 bytes written: OK
Linux rootfs=images\rootfs_linux.bin
reading images\rootfs_linux.bin
190840832 bytes read in 19490 ms (9.3 MiB/s)
NAND erase.part: device 0 offset 0xc80000, size 0x3f380000
Erasing at 0x3ffc0000 -- 100% complete.
OK
NAND write: device 0 offset 0xc80000, size 0xb600000
Writting at 0xc280000 -- 100% complete.
190840832 bytes written: OK
setting bootargs ...
bootargs=console=ttySAC0,115200n8 root=/dev/mtdblock9 rootfstype=yaffs2 rw rootwait=1 init=/init ip=off lcd=X800Y480 uart1_d_can=uart1 uart2_i2c2=uart2 rootflags=inband-tags nand=4k
NAND read: device 0 offset 0x780000, size 0x500000
5242880 bytes read: OK
烧录部分的log:
reading u-boot.bin
reading u-boot.bin
I2C: ready
DRAM: 512 MiB
NAND: 1024 MiB
cpsw, u***_ether
reading MLO
OK
reading u-boot.bin
OK
OK
OK
OK
