嗨二湾,
我重新安装了PLS UDE调试器软件4.08.06,这是最新版本。运行PLS UDE调试器并打开发现 UDE debug.wsx文件的C: SPC5Studio workspace SPC570Sxx_RLA SERIAL测试应用程序。我将SPC570S-DISP板连接到Windows 7,PLS UDE调试器能够连接到板和程序。
然后我在''main(voiu){''行设置一个断点并选择''运行程序到Cursoe - F4'',它失败了。
题:
1)是否需要额外的硬件来测试SPC570S-DISP板?我们只有威廉希尔官方网站
板和USB电缆。
2)按照安装说明后,主板在我的Windows 7 PC上创建了2个COM端口,它们是COM218和COM219,我用putty连接这两个端口,波特38400 bps,什么也没得到。这些港口是什么?如果我能成功运行导入的测试应用程序,我会在其中一个COM端口上看到“Hello World!”吗?
3)SPC570SXX_RLA发现序列测试应用是否适用于SPC570S-DISP板?我运行调试器时的错误消息,如何解决它们?
2个屏幕截图,1个显示编程正常,2个显示Run to Cursor失败。
谢谢,
工作
以上来自于谷歌翻译
以下为原文
Hi Erwan,
I re-installed PLS UDE debugger software 4.08.06, which is the latest version. Ran the PLS UDE debugger and opened C:SPC5StudioworkspaceSPC570Sxx_RLA SERIAL Test Application for DiscoveryUDEdebug.wsx file. I had the SPC570S-DISP board connected to Windows 7 and the PLS UDE debugger was able to connect to the board and program.
Then i set a breakpoint at line ''int main(voiu){'' and select ''Run program to Cursoe - F4'', it failed.
Question:
1) Is there additional hardware required to test the SPC570S-DISP board? We only have the board and a USB cable.
2) After following installation instruction, the board created 2 COM port on my Windows 7 PC, they are COM218 and COM219, I used putty to connect to those two ports at baud 38400 bps, got nothing. What are those ports? If i can successfully run the imported test application, do i see the ''Hello World!'' on one of the COM port?
3) Is the SPC570SXX_RLA SERIAL Test Application for Discovery suitable for the SPC570S-DISP board? The error messages when i run the debugger, how to fix them?
2 screen shot, 1 showing programming ok, 2 showing Run to Cursor failed.
Thanks,
Job
嗨二湾,
题:
板和USB电缆。
谢谢,
工作
以上来自于谷歌翻译
以下为原文
Hi Erwan,
Question:
Thanks,
Job
