Microchip
朱志兴
7年用户 298经验值
UB2244怎么在只读设置中访问SD卡
我想使用UB2244在只读设置中访问SD卡。我打算把写保护(SDWP)捆绑在一起,这样它就一直受到保护。如果没有使用EEPROM选项,可以在数据页的第23页7.2.3.19页中“反向SD卡写保护意义”,在SW中反转,从而否定硬件写保护。或者,如果使用EEPROM,闪光灯媒体控制器配置只能改变吗?
以上来自于百度翻译
      以下为原文
    I was looking to use the USB2244 to access a SD card in a read-only setup. I was going to just tie the write protect (SD_WP) high thereby making it always protected.
If the EEPROM option is not being used can the “Reverse SD Card Write Protect Sense” on page 23 section 7.2.3.19 of the data sheet, be inverted in SW thereby negating the hardware write protect? Or can the Flash Media Controller Configurations only be changed if there is an EEPROM being used?
回帖(1)
李蕊
2019-1-30 13:53:05
只有通过EEPROM来改变这个功能。如果你有一个车载UC,你会使用几个GPIO引脚来控制这个部件。一个保持部分复位,另一个引脚控制WP*正常应用是CD和WP都保持低。CRDYPWR需要用于向SD卡供电。记住,这是将SD卡放入已知状态的唯一方法(SD卡上没有复位引脚,因此使用PWR)。
以上来自于百度翻译
      以下为原文
    Only method to change that function is via eeprom.
If you have an on board uC you would use a couple of GPIO pins to control the part. One to hold the part
in reset, the other pin to control WP*
Normal application is both CD* and WP are held low.
CRD_PWR needs to be used to supply power to the SD card. Remember that is the only way to put a SD card into a known state (there is no reset pin on a SD Card, hence PWR is used)
