嗨,我正在尝试用FEM模拟带状线。
我经历了一个教程。 但是,我收到以下错误。 IndexError:列表分配索引超出范围Traceback(最近一次调用最后一次):文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第654行,在主文件“/ software / ads-2011_05_400 / fem_scripts / sim中。 py“,第532行,在import_settings_and_simulate proj.ads_import()文件”/home/ssaxena4/Research/HSpeed_Wireline/FEM_sims/simulation/FEM_sims_lib/dstrip_1in/layout/emSetup_FEM/proj.py“,第233行,在ads_import中波导.faces = [(part,part.faces()[0])] IndexError:列表赋值索引超出范围文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第658行,在main()中simObject.import_settings_and_simulate(stop_after_project_creation) )self.openOrCreateEMProProject(proj)文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第388行,在openOrCreateEMProProject中,模拟中止。 有人可以帮忙调试问题吗? 我试图模拟一个例子,运行正常。 但是,我创建的带状线是一个问题。 谢谢您的帮助。 SAURABH 以上来自于谷歌翻译 以下为原文 Hi, I am trying to simulate a stripline with FEM. I went through a tutorial. However, I getting the following error. IndexError: list assignment index out of range Traceback (most recent call last): File "/software/ads-2011_05_400/fem_scripts/sim.py", line 654, in main File "/software/ads-2011_05_400/fem_scripts/sim.py", line 532, in import_settings_and_simulate proj.ads_import() File "/home/ssaxena4/Research/HSpeed_Wireline/FEM_sims/simulation/FEM_sims_lib/dstrip_1in/layout/emSetup_FEM/proj.py", line 233, in ads_import waveguide.faces=[(part,part.faces()[0])] IndexError: list assignment index out of range File "/software/ads-2011_05_400/fem_scripts/sim.py", line 658, in main() simObject.import_settings_and_simulate(stop_after_project_creation) self.openOrCreateEMProProject(proj) File "/software/ads-2011_05_400/fem_scripts/sim.py", line 388, in openOrCreateEMProProject And the simulation gets aborted. Can someone help tp debug the problem? I tried to simulate an example and that runs fine. But, the stripline which I created is an issue. Thanks for the help. Saurabh |
嗨,问题似乎与端口定义有关,因此您可以尝试以下操作: - 使用不同的设置重新输入端口,例如
尝试将校准设置为“无” - 重新输入具有与布局不同连接点的端口或者,请联系Agilent支持以获取有关问题的帮助。 以上来自于谷歌翻译 以下为原文 Hi, The problem seems to be related to the port definition, so you can try the following: - re-enter the ports with a different setup, e.g. try setting calibration to 'None' - re-enter the ports with different connection points to the layout Alternatively contact Agilent support to get help with the problem. |
yahanq 发表于 2019-2-12 09:06 谢谢您的帮助。 从uW测试台开始,我是差分端口。 在FEM中,似乎我需要使用传统的端口定义,然后可以使用TML校准。 谢谢。 SAURABH 以上来自于谷歌翻译 以下为原文 Thanks for the help. I was differential ports before from uW test bench. In FEM, it appears I need to use conventional ports definition and then TML calibration can be used. Thanks. Saurabh |
1342 浏览 0 评论
2400 浏览 1 评论
2227 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1289浏览 1评论
788浏览 0评论
1077浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-27 01:04 , Processed in 1.087615 second(s), Total 47, Slave 41 queries .
