你好Winfred,
我在芯片文档中找到了有关此主题的更多信息:
1)SLEEP和STANDBY状态之间存在细微差别:在睡眠状态下,慢速时钟正在运行,但在待机状态下则不是
2)看门狗由这个慢速时钟提供时钟
3)看门狗RST线连接到一个门作为BLE RSTs线的等效输入,而BLE RST可以通过RESET引脚激活。
这些只是文档中的观察和结论,我没有在圈选中进行验证,但是:
a)如果RESET引脚可以唤醒芯片,它可以通过BLE RSTs线来实现
b)BLE RSTs线和WDG RST是门的对称输入,因此WDG RST也可以复位芯片
c)看门狗由处于休眠状态的慢速时钟提供时钟
是否意味着看门狗可以将芯片从SLEEP状态唤醒?
问候,
Piotr Romaniuk
以上来自于谷歌翻译
以下为原文
Hi Winfred,
I found more information on this topic in the documentation of the chip:
1) There is a small difference between SLEEP and STANDBY state: in sleep state slow clock is running but in standby it is not
2) Watchdog is clocked by this slow clock
3) Watchdog RST line is connected to a gate as equivalent input to BLE RSTs line, while BLE RST can be activated by RESET pin.
These are only observations and conclusions from the documentation, and I did not verified it in circut, but:
a) if RESET pin can wake up the chip, it does it by BLE RSTs line
b) BLE RSTs line and WDG RST are symetric input of the gate, so WDG RST can reset the chip as well
c) Watchdog is clocked from slow clock that is running in SLEEP state
Does it mean that watchdog can wake up the chip from SLEEP state?
Regards,
Piotr Romaniuk
你好Winfred,
2)看门狗由这个慢速时钟提供时钟
问候,
Piotr Romaniuk
以上来自于谷歌翻译
以下为原文
Hi Winfred,
Regards,
Piotr Romaniuk
